![]() | Home > Technical (L322) > caliper to hub retaining bolt torque |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35837 ![]() ![]() |
welcome to the forum Dave..
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Defo in the Workshop manual as I'm about to do this myself Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Dave Lowe Member Since: 17 Apr 2021 Location: de11 Posts: 8 ![]() ![]() ![]() |
Ok Ta found it now, its 2 stage 48ftlb and then 90deg, I thought it was a bit loose. |
On the WIKI vidio it states 48ftlb but misses out the further 90deg turn, that was where I was getting confused.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
Just be careful on the 3.6, they changed the design for 4.4 and the bolts go through the calliper, on the 3.6 the threads are in the calliper.....not ideal to put a steel bolt into an ally calliper at torque, so bear that in mind when torquing it up, you do t want to strip the thread in the calliper. Make sure you wind the bolts in by hand so as not to cross thread them..... ask me how I know |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
@drrob sure yours is 203ftlb not 48ftlb though.
oh dear that has stirred up a nets of stingy things, so I think as a relatively new guy to fatties you will understand
Are those torque settings for the rear?
This from the 06 -10 manual
Just had a look at my copy of Rave.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1422 ![]() ![]() |
Is that with the bolt dry or wet |
I do wish JLR would Standardise! You need a degree in Manual reading just to find the right page, never mind the data.
No grease! Supposed to use new bolts as well......
