![]() | Home > My Range Rover > My 2010 4.4 TDV8 |
BenRK Member Since: 19 May 2020 Location: County Durham Posts: 164 ![]() ![]() |
Very minor update. Noticed a very annoying rattle / grinding noise today, figured it was the backing plate of the front discs so decided to have a look, turns out they had rotted away at the mounting points and the plate was just flapping about, cut it off for now and the noise is gone
Well today I went on a little journey and picked up two sets of alloys to try on the Range. First set were 20s off a new sport and the second set being 20s off a new vogue. Managed to pack both sets in the back of my disco which was a task in itself.
paulwlincs Member Since: 07 Oct 2019 Location: Lincoln Posts: 44 ![]() ![]() ![]() |
Like very much all the tasks you have done , have you a link for the sill clips you got off ebay , likewise with the arch clips if you could please . 2011 tdv8 4.4 vogue Santorini black |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1342 ![]() ![]() ![]() |
I'd be interested in your old wheels if they are straight mate, Kev. |
These were the sill clips which fit perfectly
Small update, the RR has cost me quite a bit recently. The first issue was the alternator going pop in the work car park and lots of smoke coming from the engine bay, I genuinely thought it was going to set alight so quickly got the battery off and all was good
So had a few faults coming up when trying to lower the suspension. Using my fault code reader I was getting the fault 'C1A13-64 pressure does not decrease when venting gallery'
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672 ![]() ![]() ![]() |
Looking good |
Thank you, appreciate the comments
Winter wheels now fitted along with a set of new wipers and some Halfords 200% brighter main beam bulbs
Had a little adventure to Scotland for the weekend. Stayed just south of loch Lomond and had a drive up to Glencoe too. Been the third time I've been here as I just love the place, it's so vast and feels so baron at times
Since my last update there has been quite a few changes to the Range Rover, i honestly cant say for definite its for the better however. My mind is torn on which direction to go.
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 149 ![]() ![]() ![]() |
I wouldn’t worry about straying from your original plans for it. Plans change! Just get it to a state that your happy with regardless of the original vision, be it with or without various modifications, step back and admire. |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3328 ![]() ![]() ![]() |
It depends what you want to do with it |
