Home > Technical (L322) > Ride height after air spring replacement
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
Hi,
I’ve fitted a new N/S front air spring & strut and initially it’s sitting very high at the front. Can’t see in the wiki that you need to re calibrate the setting after doing this? Do need to re set heights after replacement?
Followed the workshop manual & didn’t tamper with the height sensor.
I’m still to do the O/S on Sunday so it will be done in pairs This was all pretty easy job apart from the height issues.
Rob. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #591481 16th Apr 2021 10:19pm
Check the height sensor hasn't flopped over the other way when fully jacked up... look at the one you haven't done yet... will give an idea of how it should be... Thumbs Up Pete
Post #591483 16th Apr 2021 10:23pm
RJH
Thanks Pete, I’ll check that out Thumbs Up 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #591484 16th Apr 2021 10:25pm
Also, have you driven it, they sometime wait until they move to set the ride height after being worked on... Thumbs Up Pete
Post #591486 16th Apr 2021 10:35pm
RJH
No, not moved it yet.
Didn’t have time to turn it around so finishing on Sunday.
& when it jacked up like a monster truck I thought it was odd. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #591487 16th Apr 2021 10:39pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
+1
Happened to me a few weeks ago
Post #591552 17th Apr 2021 7:05pm
RJH
Stuck my head underneath tonight & both look to be set up the same.
I'll see what happens when I move it tomorrow Thumbs Up
Need to put the iiD on & check no issues also.
Thanks,
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #591560 17th Apr 2021 8:17pm
RJH
Looks like it's settled after a short drive to turn it around.
Had a major panic doing the other side when I deflated the airbag, thought the iiD would give a choice when selecting deflated corners. No the whole lot dropped & had the front on axle stands, fortunately no issues.
Rear caliper next n hopefully all done. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #591689 19th Apr 2021 9:53am
Glad it's found it's level head again... Thumbs Up Pete
Post #591701 19th Apr 2021 10:43am
