Home > Technical (L322) > Rapid Relay Noise On Opening Door
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
On a number of occasions if I unlock the TD6 when I open the door I get about ten seconds of a relay chattering. I think it is behind the dash or in the centre console. No idea what it is or how to track it down given the intermittent nature of the issue.
Any ideas what I should be looking for?
Post #584488 19th Feb 2021 6:49pm
Gsxr1250dave
Here you go Mike
https://www.fullfatrr.com/forum/topic56054.html
Post #584499 19th Feb 2021 9:14pm
Mike Edwards
Awesome. Thanks.
Post #584513 20th Feb 2021 3:10am
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
If it's not the retaining clip, then it's the motor itself. I tried to fix mine by taking it apart but it only lasted for a few days at best. A new (used) motor cured the problem.
These are readily available on eBay and salvage yards.
And they're dirt cheap, too Wink
Post #584515 20th Feb 2021 7:38am
Mike Edwards
According to Land Rover these motor units are no longer available to buy new.
The big question is, given that there are four of them down there, how to work out which is the problematic one without pulling the whole dash apart.
Or is it obvious once you have pulled the dash apart which one is the suspect one?
Post #591630 18th Apr 2021 6:10pm
Gsxr1250dave
I took mine apart it's pretty simple I cleaned it greased it been as good as gold since.
There is x1 in the footwell then 1 or 2 behind the hevac panel both easy to get to.
Post #591635 18th Apr 2021 6:17pm
