Home > Technical (L322) > E10 and the 4.2 Supercharged..
Danwilderspin
So looks like we are all going to be forced down the 5% more ethanol 5% less range route of E10 (seems like a scam to me ?!?)
Anyway Reading into it it says its a lot harsher on components than what we currently have.
Now, being that the 4.2 supercharged and 4.. AJ engines are good workhorses except when an log conversion is done badly - what's the likelihood of this causing problems to said engines? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #591972 21st Apr 2021 10:16am
dingg1
None, because you're running on gas 99% of the time
Post #591975 21st Apr 2021 10:45am
dingg1
Or do you mean on non converted cars?
I think they run 10% ethanol in 95% of petrol sold in the USA, so again the answer is the same, no issue...
Post #591977 21st Apr 2021 10:48am
Danwilderspin
Yes sorry non converted but even gas usually switches back around 4k Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #592007 21st Apr 2021 5:02pm
wack61
Just put E5 in it, I refuse to put E10 in any of my cars, even the smart car
Esso E5 contains no ethanol at all in most of the country, tells you on their website where it does have ethanol in it
Post #646458 25th Oct 2022 9:09am
wack61
Post #646459 25th Oct 2022 9:10am
Sandyt
+1 I have always used E5 in our vehicles and also in the boat the ethanol rots some of the less robust metal components in the fuel line the p38 is on 190k and the l322 228k no issues with either
Post #646482 25th Oct 2022 1:24pm
dhallworth
When my SC was on LPG the only petrol that got put in the tank was E5. Now the LPG has been removed I still only put E5 in it.
Ethanol has a lower calorific value then petrol so when you use E10 you'll use more of it. Granted, it's probably not that much but you'll still need more. Using E5 will reduce this slightly as there's less Ethanol in it.
Any petrol car I've got these days, including lawn mowers, strimmers, chainsaws, quad bikes, etc. all get E5 in them now.
Although, for the non car stuff I've been looking at buying drums of storage petrol as that's entirely Ethanol free.
Post #646504 25th Oct 2022 4:49pm
Sandyt
I have been using Aspen fuel in my garden stuff and other tools an d can leave them over the winter without having to muck about with them and its been brilliant
Post #646600 26th Oct 2022 8:04pm
