Home > Technical (L322) > 3.6 TDV8 Number 8 injector
Smiggy
United Kingdom 2007 Range Rover Vogue TDV8 Zambezi Silver
Evening,
I had a cracked inlet manifold/rocker cover.
I have replaced that which involved splitting injector number 8.
Ever since I have had issues with the injector. it was ticking loudly and running rough. On my iid it was running around 5-600 with the other running around 1200,
I have just purchased another used injector to see if that will help. Now that injector is running around 1300 and the other 7 are around 600. At just over tick over it sounds like a old tractor, as soon as the revs pick up over 1000 rpm its drives great with loads of power and no smoke.
Does anyone know what the numbers mean?
Are there different injectors for different cylinders?
Do the injectors need calibrating?
I wish I had just loosened the engine mount and lifted the engine now to remove it Big Cry Big Cry
Any help and info would be greatly appreciated.
Cheers
Craig
Post #592026 21st Apr 2021 7:50pm
Smiggy
Good news update.
I ended up buying a new injector. Fitted it by loosening 2 engine mounting bolts, jacking the engine up a couple of inched and removing the plastic that surrounds the battery compartment.
Finally the car is now running properly Very Happy Very Happy Very Happy Very Happy
Post #595206 24th May 2021 6:01pm
t5pete
Great news I too have just had the manifold split on our 4.4 and the lifting of the engine seems the way to go as I was worried regarding splitting the injector and causing issues also dont want to dish the inner wing to enable removing.
Post #595213 24th May 2021 6:52pm
Smiggy
lifting the engine is the way to go. Shame it cost me £300 for a new injector to find this out Censored
Post #595215 24th May 2021 6:56pm
