![]() | Home > Technical (L322) > Can it be non-jumpstartable ? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
Was two days enough ?
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591 ![]() ![]() ![]() |
Thanks Joe, can it die enough to need more? Put it on again last night and even boot won't open today, don't mind buying a new battery but surely I should be able to start the |
So another 3 days with this thing on the charger, all the lights etc. however nothing else, any ideas people?? maybe a petrol can and a match..... |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Could well be the battery is just completely dead mate. Best thing I'd say is get the aa out to try and jump start it. When my alternator went, it was on my drive for 2 days while I waited for the new one to turn up so not long but the battery needed the aa jump pack and a direct leads from their van so they do take a fair chunk. Leave it to run for 45 mins idle and watch a film inside the car. After this try checking the battery with a volt tester and see what's happening |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
A few months back my battery started to die and needed frequent charging. I have a good 'Ring' charger with different charge rate settings and a 'Car start' setting. If there was some change left in the battery, but not enough to start up, I could jump start it and change the battery fully as I used the car.
Thanks Chaps, new battery it is then, alternator replaced about 3000 miles ago so hopefully only battery, |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3273 ![]() ![]() ![]() |
you can use a super booster charger to bring a dead battery back to life. My neighbour has one - it's a big red box and you can set the charge rate. I used it to bring a dead battery to life in my merc when my normal charger didn't work.
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
I had a dead battery on mine that wouldn't start, would not take a charge and no display
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
when trying to jump start there are jump leads and there are JUMP LEADS.
Treebor99 Member Since: 07 Feb 2021 Location: Rugby Posts: 34 ![]() ![]() ![]() |
I remember reading somewhere a few years back car starter batteries are not designed to be completely discharged. Doing so will damage the batteries capacity and could even kill it completely. They are designed for rapid short bursts of energy only.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1428 ![]() ![]() ![]() |
Might you need a system re-set (hard or otherwise) following the battery having been completely drained? It does seem to take a lot of charge to get the TDV8s to start, on one occasion when my battery had been flattened by a locking software fault the LR Assist operative needed his van running for a while on jump leads, plus a booster pack before anything happened. Only Range Rovers since 1988 |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 461 ![]() ![]() ![]() |
As has been mentioned if the battery gets below a certain point it does not provide the signal to the charger that there is even a battery connected and therefore it receives no charge (I believe the correct phrase is "back EMF" (electro magnetic force).
