![]() | Home > Maintenance & Mods (L322) > Draining Oil FFRR 2012 4.4L TDV8 |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3258 ![]() ![]() ![]() |
There is a pump oil pipe next to the oil filler. That is the best way. We all use a syphon or pump. Do a search on here for the various models used. |
robkuijpers Member Since: 11 Apr 2019 Location: Zeist Posts: 36 ![]() ![]() |
Thanks Dolphinboy
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
There will be some 'pollution' left behind but it will be diluted to a point where it's irrelevant, after all, you were running with a sump full of the polluted oil before the oil change. BMW i3 Electric Car
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4344 ![]() ![]() ![]() |
The first drain picture you posted is for the turbo drains. You should get very little out of it.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
i change my oil so regularly i don't bother with the sump drain at all i just syphon it out. i change my oil 3 times a year regardless of mileage. When i change the oil it gets syphoned out at full temp too.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8771 ![]() ![]() ![]() |
Just keep an eye on the seal on the bottom drain, as it’s only a push fit it’s not very tight. My 12my leaked at that joint, LR did replace the whole pipe under warranty but I think it’s a fairly big part not just the elbow.... There is nothing that can't be fixed with a hammer😜😜
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3873 ![]() ![]() ![]() |
I have had B.B. seven years now and have sucked out the oil twice a year throughout.
mattgage Member Since: 21 Apr 2014 Location: Suffolk Posts: 38 ![]() ![]() ![]() |
Yep another vote for a vacuum suck twice a year and an oil and filter kit of the right stuff from Opie Oils. Very easy. I also add some fresh oil into the engine once it's emptied, let this work its way down, then remove that before refilling with new.
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 300 ![]() ![]() ![]() |
That Pela 650 only holds 6.5 Ltrs but, according to DrRob, the sump holds 9ltrs. Do you do the extraction in 2 lots?
Yep - two lots, and straight into 5 litre old oil bottles. Just release the pump vacuum pressure halfway through. You can count out the litres as you remove it. |
