![]() | Home > Maintenance & Mods (L322) > Broken coolant pipe |
| Tattiepicker Member Since: 01 Apr 2021 Location: Aberdeen Posts: 51
| rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198
I think you will have to replace the whole unit.
Yeah I kinda thought the whole unit would need replaced. Thanks for the help, this oil cooler gasket job has grown arms and legs |
Yup, and one of those arms always finds its way into your wallet |
| mattgage Member Since: 21 Apr 2014 Location: Suffolk Posts: 38
It's not a bad pipe to replace as the O rings can rot, creating coolant leaks. |
The part number for the replacement full unit is LR022690. Hopefully I don’t break anything else whilst fitting it.
Yep those wee bolts are amazinglybweak. One of mine broke and had to be replaced. Luckily got it out after some mole grip action and WD40. |
Yeah I had all sorts of tools to remove them. Found a ring type spanner that fitted snug over the round base, held at a slight angle was enough to loosen the bolt and then rotate with long nose pliers, the back right one is in a particularly poor area for access. Lots of profanities later and they were all out. |
Once I replace the water outlet top connection. Is there any special procedure for topping up and/or bleeding coolant or is it a case of just keep an eye on the expansion tank level and keep topping up as required. Any special coolant required or just the standard one in the specs but any brand? I have the pink coolant in mine. Thanks in advance. |
