Home > Wheels & Tyres > Tires for road and soft sand beach
hamiamham
United States 2008 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
I have a 2008 Supercharged (full sized) that came standard with 20" wheels and 255/50R20 tires. I am in the US so it is NAS and left-hand drive. As far as I know we don't have any "tire police" here so I am free to choose any tire that fits...
Thus far I have chewed thru 2 sets of tires by doing sidewall damage to the tires while driving aired down on the beach.
So a couple of questions:
Assuming no lift kit or other modifications, what tire height can I fit. I am thinking I would like to keep the 255mm width but increase the ratio from 50 to 55 or even greater.
I need to air down to at least 20psi but would prefer as low as 15psi; any recommended tire brands that have a sidewall that can handle this task?
I live on a small island off the coast of the Northeastern US. The max speed limit is 45mph and while we do get rain, it rarely snows.
Post #592627 28th Apr 2021 9:41pm
Plenty of folks run 255/55/20 on the 322, they are the standard fit on the 405 so folks bought the 405 alloys with the tyres and put them on the 322.
If you want to get a taller side wall then you could go smaller on the wheel. There is nothing that can't be fixed with a hammer😜😜
Post #592629 28th Apr 2021 10:05pm
hamiamham
Thanks for that. Any tires you can recommend?
Post #592676 29th Apr 2021 12:37pm
bishbosh10
32" seems to be the biggest practical diameter. Even then you might get rubbing at full lock / articulation. Rubbing is increased if you go wider for obvious reasons.
When getting bigger tyres think about what you'll do if (when? Shocked ) your EAS packs up and you are on the bump stops. If your tyres are in contact with the wheel arches you're in a world of pain!
Personally I would look at the smallest rims you can fit over your brakes and limit the overall diameter to something a bit less than 32". That way you'll get the deepest sidewall which will give you the most benefit when airing down. Obviously a robust tyre choice with decent side walls is a must. Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #592686 29th Apr 2021 1:11pm
hamiamham
I am going to order a 18" rim and have the mechanic test fit to my car. Assuming it fits I will have a number of tire choices. If it does not fit, I will go with a 19" wheel which - while not ideal - does allow me more side wall height with the same tire diameter. My air suspension has given out on me in the past so I would like to avoid the bump stop issue if I can.
Post #593782 10th May 2021 2:24pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
I am sure the only 18" that will fit over a supercharger brembos is the one made by Compomotive, I may be wrong and you may have different options over there Thumbs Up
Post #593784 10th May 2021 2:58pm
Pretty sure rosco is correct in his thinking.
Don’t think any L322 18” will fit, though you may find a D4 wheel does but I’m not 100%. There is nothing that can't be fixed with a hammer😜😜
Post #593786 10th May 2021 3:07pm
