![]() | Home > Maintenance & Mods (L322) > Recommendations for dog guard and liner |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
I have this combination. Worked well for our Labrador retriever whilst also having the car filled up with holiday gear last summer...
CongoBoy Member Since: 11 Sep 2020 Location: Wiltshire Posts: 126 ![]() ![]() ![]() |
Thanks, Blackdog. I
bluebottle Member Since: 16 Apr 2021 Location: The M3 Corridor Posts: 157 ![]() ![]() ![]() |
If anyone has any thoughts on this I would be interested. I have a pretty nice looking carpet in my boot and I would like to keep it that way...
I’ve got an official Land Rover rubber soft cover over my luxury carpet in the boot. Seems to do the trick for our Labrador retriever. |
LT Member Since: 13 Mar 2017 Location: South West Posts: 414 ![]() ![]() ![]() |
I prefer a cage/crate but have a Hatchbag liner with the LR flexible mat over it. |
I like a crate too. But to my surprise his crate doesn’t fit in the back of the FFRR. It was perfect in our Mercedes GLS but the Range Rover is too small to put it length wise. And if I was to put it sideways then it becomes awkward with the rest of the luggage. Hence I had to buy what was linked above. |
dimetrius Member Since: 20 Apr 2021 Location: St. Petersburg Posts: 24 ![]() ![]() ![]() |
Here's a page out of the original catalogue that has all the original item codes:
This looks rather nice! 2009 Range Rover Westminster 3.6 TDV8 Alaska White/Jet |
speaking of crates, MB makes the perfect collapsible plastic crate for "stuff", and it's cheap - A2038400020
nice to see other lab lovers around here! 2009 Range Rover Westminster 3.6 TDV8 Alaska White/Jet |
MonkeyMan Member Since: 20 Apr 2021 Location: Ascot Posts: 133 ![]() ![]() ![]() |
For my last 2 cars I have ordered custom made liners from www.overthetop.co.uk
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 352 ![]() ![]() ![]() |
I used custom car covers for the boot hatch bag and I’m very pleased with it, for the dog guard I bought the landrover luggage/dog guard roller net both work perfectly with my pooch 2012 Range Rover Westminster 4.4 TDV8
Given I don’t actually have a dog, I’m thinking a cheap cover like this and then a rubber mat to protect the tailgate when it’s down should be ok? 2012 L322 TDV8 Vogue SE: Buckingham Blue
Depending on the dog(s) that may even be an overkill ![]() But this should keep your post-trip cleaning to a minimum, even if you've got two labs who'd had a go in mud ![]() It's probably also worth considering a thick polyester blanket/bed cover for the tailgate. I like the ones from Ikea. Dogs claws are not as sharp and tough as may seem at first, they are not wolverines! A rubber mat for the tailgate may get in a way. At most you'll get a barely visible scratch on a plastic if you don't cover it with anything. If you go the bare route, depending on the dog, you may want to put a blanket over the rear seats, so the dog doesn't accidentally scratch the leather. The blanket for the tailgate is to make it psychologically easier for the dog and protect the carpets from water/mud/sand/dirt. If the dog is fairly clean, i.e. not after a long walk in the rain, you don't really need anything for the cargo space, maybe a blanket or a dog bed to keep the pooch happy. Be prepared to help the dog up - RR is quite high, if a particular dog isn't used to jumping into cars, it may require a bit of negotiation with treats, or plain old catch and carry ![]() |
Thanks for the tips dimetrius - and apologies to the OP for hijacking this thread...
