Home > Technical (L322) > L322 Door Locked. Please help.
andylouca
2003 Range Rover HSE Td6 Java Black
Hi all, please can anyone help as my TD6 front passenger door is locked and I cant find a way to open it. I have removed the trim along the top of the door and can see into the door. The cables are connected and the lock mechanism all seems to move freely but the door will not open. I have stripped the drivers door to see if there is anything different but it all looks to be working the same. The only clue I can offer is the door button doesn't go up with the others but you can pull it up although it pulls its self back down again. Everything has been sprayed with WD40, there is no rust. I am stuck. Many Thanks.
Post #59285 7th Apr 2011 4:40pm
Vogue
if you do a search there is a lot of info on here - I have done several posts on this subject - oh and welcome Very Happy
Post #59288 7th Apr 2011 4:42pm
