Home > Technical (L322) > 2011 indicator fix? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
I'm afraid I've never seen a fix yet! Failures are few and far between... Doesn't help you though I know! |
2nd May 2021 12:27pm |
TJRL Member Since: 07 Sep 2019 Location: Reading Posts: 198 |
Wow! £1.4k for an indicator relay?
2nd May 2021 3:34pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1141 |
Graham Nic is referring to the cost of a complete new headlight unit, which I assumed could not be opened to exchange the LED indicator unit.
2nd May 2021 4:21pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34916 |
is it the indicator stalk that you are referring to or that the indicator lights not working..
2nd May 2021 4:33pm |
Graham Nic Member Since: 11 Mar 2020 Location: Lerwick, Shetland Posts: 16 |
Hi Stan, it is the headlight unit that's faulty. I swopped over the units to eliminate the module and the fault is in the unit it's self. |
3rd May 2021 7:36am |
Hi, I have seen videos of fixes on earlier units ((06-09 models), so I know how to separate the unit, but there is no point in doing this unless I can get the part to replace the defective bit? My local spares shop say that there is a part number listed, but the company don't sell/stock it? Probably JLR still hold the patent/licence on the part? |
3rd May 2021 7:43am |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1131 |
Have you tried BBA Reman? When I contacted them about a rear light? They said that they could take it apart.
3rd May 2021 8:38am |
Hi, thanks for the info, I will give them a shout and see if they can help? Cheers |
3rd May 2021 9:14pm |
