Home > Technical (L322) > Charging, Discharging, Starting Help! FIXED
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
L322 2011 4.4TDV8 AB is new to me, yesterday I received my IID and pulled up the following codes:
Any ideas?
Battery, alternator, SM been proactively replaced and working well.
FEM-Navigation
U2101-00 (2F) Control module configuration incompatible
( on 02-05-2021 20:31:37 at 189783 km )
HVAC-Ventilation. FIXED had to replace 4 damper motors that were faulty
B1085-87 (2F) Defrost damper motor - Bus signal/message failure - missing a message
( on 02-05-2021 20:31:48 at 189783 km )
B1087-54 (2F) LIN bus A - System programming failure - missing calibration
( on 02-05-2021 20:29:30 at 189783 km )
B11E3-87 (2F) Rear heating ventilation air conditiong damper motor - Bus signal/message failure - missing a message
( on 02-05-2021 20:31:46 at 189783 km )
B12D0-87 (2F) Foot damper motor - Bus signal/message failure - missing a message
B12D1-87 (2F) Dynamic air pressure damper motor - Bus signal/message failure - missing a message
IPMB-Camera Fixed, connector has some oxidation with moisture ingress
B12BD-49 (2F) Rear camera - System internal failure - internal electronic failure
( on 02-05-2021 20:31:39 at 189783 km )
PCM-Engine TDV8 4.4L Fixed after ECU tuning
P040D-00 (2F) Exhaust gas recirculation temperature sensor A - circuit high
( on 02-05-2021 20:31:43 at 189783 km )[/b] SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #592981 2nd May 2021 9:32pm
GraemeS
Australia
Best to clear all the codes then keep an eye on any new codes.
The common PCM EGR fault will most likely return but it's innocuous on our vehicles that don't have a DPF. The cause is a faulty sensor in the left exhaust manifold which is had to get to. The sensor was later revised which suggests a design or manufacturing short-coming for the original version of the sensor.
Post #592982 2nd May 2021 9:37pm
ffrr14
Thanks Graeme!
I have cleared it, but all of the above come back Sad
Car is going to Cam for apple carplay setup tomorrow, will clean the sensor fan and etc.
Also do I bother with the EGT sensor?
LR052169. <<<correct code?
JLR-303-1573. <<<tool SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #592983 2nd May 2021 10:14pm
cass
Do you have any physical symptoms that are a problem?
If it’s just the codes then I wouldn’t worry about it, I have convinced myself that every JLR car is fitted with a random code generator that is simply there to cause paranoia thereby providing revenue for the impoverished main dealers
Post #592984 2nd May 2021 10:21pm
ffrr14
Thanks for that
- Battery Drain
- Also noticed a fan + cycling noise with a pop coming from the dash area when the car is in ignition on but not running.
EGT is as Graeme explained SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #592985 2nd May 2021 10:27pm
ffrr14
Can I hard reset the CAR? what is the process/Impact? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #592989 2nd May 2021 10:33pm
Arbuckle
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
There are guides on here under Wikis.
Ensure battery is fully charged using battery charger before starting this.
This works for me:
Engine off, ignition off;
Open bonnet;
Shut doors and move remote away from vehicle;
Wait 20 mins for all the computers to do their shut down thing;
Remove negative lead, then positive lead from the battery;
Leave for 10 mins;
Short the two leads together;
Leave for 10 mins;
Reconnect positive lead;
Reconnect negative lead in one single touch. (avoid multiple contacts);
Leave for another 10 mins or make a cuppa, for systems to reboot.
Press start button (ignition on) but not start engine yet;
After 2 mins, start engine;
Turn steering fully left then right and return to centre (sets steering centre position sensor);
Not everything works straight off but will return in first few miles;
Oh, and reset clock !
Good luck Forty years of progress. 1972-2012
Post #592995 2nd May 2021 11:05pm
ffrr14
update
Faults gone:
FEM-Navigation
Remaining:
HVAC-Ventilation
( at 189845 km )
( at 189845 km )
( at 189845 km )
( at 189845 km )
( at 189845 km )
IPMB-Camera
B12BD-49 (6C) Rear camera - System internal failure - internal electronic failure
( at 189845 km )
Carplay added
Engine tune added
EGR Closed
Wah what a difference!!
275 kw
368 hp
810 nm SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #593107 4th May 2021 12:10pm
Lots of the above codes are battery related... The P codes are legitimate codes... B's & U's are usually spurious codes issued when the battery volts dip during the starting procedure Thumbs Up
Post #593169 4th May 2021 8:39pm
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
So what needs changing to resolve this error?
"The cause is a faulty sensor in the left exhaust manifold which is hard to get to."
Is it just a new sensor or should we just ignore it until we notice a problem?
Post #593177 4th May 2021 9:43pm
ffrr14
I have not had a chance to replace it yet, but after the remap and egr closure it seem to have disappeared. That said is there a case of shoot build up etc that gets cleared with a bit of spirited driving ? Idea
Dont have a conclusive answer, but keep an eye on it. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #593188 4th May 2021 10:30pm
ffrr14
Charging seems to have resolved with clean up of BMS wiring.
Starting is also resolved, car starts with a fully charged battery. I also have secondary battery system from Traxide with Yellowtop.
Drain is persistent, I haven't had a chance to diag.
Observation:
Car locked drain is around 30~40ma
Car seems to wake up every two hours for about 30 min to do stuff??!! as per the graph. Is it compressor or is it FBH?
Any ideas? Thanks in advance.
New : G350D
Post #596788 8th Jun 2021 5:09am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
I'm not sure how you deduce the car is waking up when the voltage rises? If the car is truly waking up you would expect the voltage to fall. It wont be the FBH or the Compressor. Are you saying that when the car wakes up it connects your second battery into the circuit?
The 30-40mA I would have said is a very acceptable constant discharge. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #596790 8th Jun 2021 6:38am
ffrr14
It is dropping right
The second battery is recent, but the noise pre dates it.
I will have to do some old fashioned probing the long weekend.
R1 is glove compartment and corresponding in the rear is during sleep, any ideas?
Thank you SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #596792 8th Jun 2021 7:19am
ffrr14
FIXED
Few learnings, will updates in a bit SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #599208 30th Jun 2021 3:10am
