![]() | Home > Maintenance & Mods (L322) > Fitting Tow bar |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1197 ![]() ![]() ![]() |
If it's designed to fit your FullFat, then I would expect you can use the original mounting bolts for the brackets that come off the car. If you want to replace them, then remove and measure up the originals, allowing for any differences in material thickneses. Then speak to Duckworths about it.
Andygriff73 Member Since: 30 Jul 2018 Location: Ellesmere Port Posts: 68 ![]() ![]() ![]() |
Duckworths sell new bolts I think I paid £4 each there are 4 of them then reuse the 8 nuts that hold your bumper bar on I fitted mine on my own with the help of an engine crane set aside a day to do it and use the boiling water method on the rear bumper sides to avoid breaking the lugs loads of info on the forum. |
RSW Member Since: 13 Oct 2015 Location: Devon Posts: 44 ![]() ![]() |
Thanks guys, all I need now is a bit of time |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
That doesnt look like a genuine JLR tow bar! Therefore I'm not sure if the bolts that hold the tow eyes on your car will be the same to fit it! Does it have a makers name? |
