Home > Technical (L322) > Bi xenon headlight fault
Tesh
United Kingdom 2004 Range Rover Vogue Td6 Java Black
I have recently facelifhted the front of my FF with second hand parts. every thing weas working fine untill the headlights started playing up
My mainbeam is no longer activating the shutters on my bi-xenon headlights so now I only get halogen bulbs lighting up
A couple of weeks ago the main bean xenon shutters stuck on and I couldnt switch them off untill I turned the ignition off. I could understand it, if only one head light went off, but both together?
Anyone got any ideas Crying or Very sad
Post #59319 7th Apr 2011 8:53pm
daveo
did you do the facelift your self and if so ow did you wire up the high beam flash V8 facelift Range Rover Autobiography 22" wheels.
Post #59325 7th Apr 2011 9:14pm
Tesh
Yes I did the facelift myself and it all was working fine
I havnt got the wiring diagram with me at present
Post #59326 7th Apr 2011 9:23pm
daveo
is it the 2002 to 2006 or to 2010 V8 facelift Range Rover Autobiography 22" wheels.
Post #59331 7th Apr 2011 9:30pm
Tesh
2002 to 2006
Post #59334 7th Apr 2011 9:36pm
dan_uk_1984
The shutter runs on pins 5 & 6 from memory... On mine - I ran these to the centre halogen hi-beam lights so as soon as these come on the shutter lifts.
I just used a loop of wire about 2 inches long...
Dan
Post #59340 7th Apr 2011 10:01pm
Tesh
I just followed the wiring diagram that came with the plugs and all worked ok untill the other night
I'll have a look over the weekend to see if anything of the connections have worked loose
Post #59422 8th Apr 2011 3:32pm
