![]() | Home > Technical (L322) > 3.6 TDV8 Losing coolant and grey smoke - still no root cause |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 698 ![]() ![]() ![]() |
'the thermostat housing is leaking slightly but,'
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
A leaking thermostat doesn't explain the smoke. 2015 Range Rover Autobiography 4.4 SDV8 |
Correct, it doesn't. But it could be part of the problem.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4341 ![]() ![]() ![]() |
Which garage are you using? Plenty of good LR independents round Hampshire to choose from... |
jonminns Member Since: 07 Mar 2011 Location: Leicestershire, UK Posts: 155 ![]() ![]() ![]() |
If you want my (not professional, but having spent lots of hours under the bonnet of my 3.6) opinion:
The garage have done a block test today and have a negative result so, this means a problem with the head gasket. The lack of any other symptoms such as steam or mayonnaise probably means it's early days.
Well, if you’ve got a warranty, with all due respect......use it! I’m guessing that any excess would outweigh any faffing about with sealers etc etc.
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 412 ![]() ![]() ![]() |
I'm way worse than that...
I'm convinced it's not.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 959 ![]() ![]() ![]() |
Hi Gary, I am getting grey smoke at high motorway speeds ( but I have a petrol V8 ) , but just curious if you found what was causing your smoke issue ? |
Blown head gasket(s) 2015 Range Rover Autobiography 4.4 SDV8 |
