Home > Technical (L322) > Gap iid ECU software updates.
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Hey guys, just recently purchased a gap iid tool 2nd hand all transferred over to my car (thanks Graham).
I did a ECU software scan and came up with new firmware updates for several things on the car. However, I'm a bit dubious on installing them in case I brick any of the ECU's. So could any of you technical experts on the gap tool and firmware updates give me any info on the attached pics and give me some advice on whether to proceed or leave well alone? Your help will be much appreciated.
Post #593519 7th May 2021 6:44pm
If it ain't broke, don't fix it....
Every update has the potential to go wrong...!!
Pretend you never saw the updates... Thumbs Up Pete
Post #593521 7th May 2021 6:53pm
cass
Excellent advice
Why do you want to do the updates? What is wrong with your car that you think the updates will fix?
Post #593539 7th May 2021 9:21pm
DrRob
Don't mess is the concensus Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #593560 8th May 2021 8:14am
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Obviously JLR just write the updates for fun rather than to actually fix real issues?
Is there no documentation available explaining the changes in each update?
Post #593595 8th May 2021 11:51am
misfire84
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
Dont Mess !!!!
Post #593598 8th May 2021 1:00pm
Tell that to the Toyota owners who lost over 50bhp following an ECU update done at a service
Toyota refused to revert them quoting some emission crap as the reason...!!
Updates are not always an improvement... Thumbs Up Pete
Post #593619 8th May 2021 5:44pm
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Standard IT software updates, check what it's there to fix and if you have that issue then you should be updating. Otherwise as others have said leave well alone.
Post #593646 8th May 2021 9:47pm
Range Rover L322
This is a forthcoming IIDTool update that is worth doing when released.
Post #593648 8th May 2021 10:12pm
Mike Edwards
I suspect you will find it was still to fix a problem that didn’t involve emissions.
I had a 3.0 Vito Sport for a while and every six months another attempt was made via updated firmware to fix the DPF regen as they had made a mechanical screw up when designing the engine installation that then had to be ‘fixed’ in software.
Post #593664 9th May 2021 2:01am
Barmybrummie
Thanks guys. It's just this is my first ever FF and still getting used to it. I do know the gearbox was reconditioned 2 years ago before i had it at a nice cost of £2500 but I personally think the gear changes are not as what I expect, it could just be me not being used to it. I am blanking off the egr's when I get time and read on here that should make gear changes more smoother. Hopefully I will be able to do that this weekend weather and time permitting as I work abroad during the week. Clearly I don't want to do anything untoward in killing any ECU's.
Post #593821 10th May 2021 9:09pm
