Home > Technical (L405) > Battery Charging |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
I also use a CTEK, I assumed it was just the main battery as aren't the terminals under the bonnet the jump start point aswell , however, saying that, I assume the auxiliary battery is charged via either the alternator or via the main battery when the car is running? I would also be interested to know now Steve
30th Jan 2019 2:53pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7762 |
I would expect so, but not sure - will need to get a meter on them to test it out someday
30th Jan 2019 3:56pm |
5.0 Member Since: 25 Feb 2012 Location: Surrey Posts: 709 |
The reason I ask is because my car is sometimes not used for long periods and is kept on a CTEK charger connected under the bonnet. Whenever I use the car after an extended period of it not having moved, the tailgate will not close either with the button on it or with the key fob. I just get a beeping sound and I have to close it manually. After the car has had a good run it then works perfectly. Therefore I was wondering if this was caused by the auxiliary battery running down because it wasn't being charged by the CTEK and was only charged when the engine was running. |
30th Jan 2019 5:30pm |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 771 |
I connect my CTEK directly to the battery under the spare wheel. I have fitted a CTEK extension lead to save having to move the spare wheel each time. I have also connected a small solar charger to the same battery when leaving the car for several weeks. No problems whatsoever with either charger. MY23 D350 HSE
30th Jan 2019 6:43pm |
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 183 |
Bearing in mind that the aux battery is connected under the control of the battery monitor, I doubt it. The only way to be sure is to check the voltage across both batteries with your CTEK charger connected.
30th Jan 2019 8:06pm |
fin Member Since: 20 Oct 2010 Location: South East London Posts: 50 |
Phil
9th Feb 2019 8:36am |
It’s something like this, but this is probably better than mine. I connect it in the boot and drop it on the rear parcel shelf near a side window. Works fine even if your windows are tinted.
9th Feb 2019 10:29am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3677 |
Why oh why don’t they offer one built into the sunroof to permanently float the battery whenever sunlight is available.
9th Feb 2019 10:45am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3646 |
I know this is an old thread but it asks the questions I have. In the manual it only talks of one battery (not two) so that’s my first question do all L405s have two batteries if so where’s the second. As I’m not using it much when I go to start it I get the “low battery -start engine” message. It always starts no problem but as a precaution I would like to connect my c-tek. I’ve always done this using the adapter I got from this site via the towing electric but as the towbar won’t deploy (another story) I need to connect differently - can I just use the jump start connection points under the bonnet.? Geoff |
8th Feb 2021 9:19am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34924 |
charge from the points in the engine bay ...
8th Feb 2021 9:39am |
Sacimiddx Member Since: 01 Aug 2015 Location: Hants Posts: 43 |
https://www.fullfatrr.com/forum/topic58249.html
8th Feb 2021 7:13pm |
Crasher242 Member Since: 07 Mar 2019 Location: Warwickshire Posts: 132 |
Thanks for this - this weekend just gone was the first time I got the Battery Low - Start Engine message. I've put this down to the particularly cold weather of late.
1st Mar 2021 1:48pm |
Gold Ranger Member Since: 31 Mar 2017 Location: East Midlands Posts: 33 |
sorry to jump this thread but hope someone can shed some light or has any suggestions
7th May 2021 8:57pm |
It's in the wiki - https://www.fullfatrr.com/gallery/albums/u...cables.pdf |
7th May 2021 10:03pm |
