Home > Maintenance & Mods (L322) > Iid Tool & DPF Numbers
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Playing around with my newly acquired IID Tool - are these DPF figures good or bad? Sometimes ignorance is bliss!
 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #593608 8th May 2021 2:10pm
Dolphinboy
look fine to me. Thumbs Up
Post #593638 8th May 2021 7:44pm
Range Rover L322
RR2B, this is a rabbit hole. If you want to go down it, I suggest putting the mileage up on your IIDtool and seeing how many miles per gram of soot you get. Also the Bank 1 Sensor 2 temp. If you watch those, you'll get a feel for what's happening.
The partial regen field does not populate.
However, it is worth bearing in mind this is only an actual problem for a tiny handful of the estimated 100-200,000 L322 TDV8s built, and people are often mislead because fixing the issue is counter-intuitive. They often think if the DPF is blocked it must need cleaning or removal or replacement, however the DPF itself is just a ceramic filter which is cleaned either in the course of normal driving or during a regen by having fuel dumped into it.
The DPF almost never goes wrong. In fact I can't remember anyone ever conclusively having a DPF fault - it is just a receptacle. DPF warning lights are invariably a symptom of another problem and the DPF is never the cause: the issue is how the car is used (like only doing short urban trips (go buy a VW Golf!)) or an induction hose split, MAF Filter or finite number of other causes. You can read more here: https://www.fullfatrr.com/forum/topic48068.html
If you are not getting a Yellow or Red DPF full warning light I would leave it. Don't fix something that's not broken kind of thing. The IIDTool has an update coming which will address it anyway.
Post #593649 8th May 2021 10:27pm
DrRob
No Yellow or Red DPF light? Don’t look at your IID or it will drive you nuts Rolling with laughter
Mine gets to around 19 then starts a hot burn but I rarely monitor it to save sanity Laughing Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #593668 9th May 2021 9:42am
