![]() | Home > Maintenance & Mods (L405) > L405 Coolant Leak From In Front Of The Rear Wheel. |
For anyone following "MY NEW CAR" thread? Yes i have JLR warranty and for some reason "beyond my understanding" the warranty refused to replace this pipe! |
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 ![]() ![]() ![]() |
I cannot understand what your moaning about
Me moan sir |
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 ![]() ![]() |
I’m told the Land Rover Approved Used warranty only covers ‘sudden’ mechanical failure. Corrosion is not not considered a sudden failure. This may be the same for other manufactures too, but I find it difficult to accept that on a £100k off road vehicle this level of corrosion exists after 4 years. Current MY2020
Yet they Okay'd the replacement of the front suspension struts/air springs without question? Cost wise, I'm very glad they did, obviously! But i cannot understand it... |
Agreed, there is no consistency.
randomusername Member Since: 28 Mar 2017 Location: Wilts Posts: 56 ![]() ![]() |
What you need to do is to find a local indy specialist that can fix all these little niggles for you...
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 672 ![]() ![]() |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
I think you may have found the issue there.
It’s been done |
Looks like they replaced the pipe? |
It’s under Approved Used so went into the main dealer for the work, usually I’d just have used a piece of pipe myself.
That was going to be my next statement! They left off the offending clip!
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
The pipe without the clip looks like it’s just a sheath? it’s a different diameter to the ally pipe. 2011 (MY12) 4.4 TDV8 Vogue
