Home > Technical (L322) > Fuel filler door not staying open
stevepen
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
The door on my fuel filler won't stay in the open postition and makes filling up a pain.
Am I missing anything from the pic?
 2011 Vogue SE TDV8
Post #593876 11th May 2021 3:14pm
Looks the same as mine, which stays open, so maybe something missing a bit deeper in there...
 Pete
-Click here for Thread-
Post #593889 11th May 2021 5:21pm
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Exactly the same issue here! Nothing obvious missing, just doesn’t want to open to 90 degs. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #593900 11th May 2021 6:20pm
stevepen
Yes, it's a strange one. No resistance at all as though it's just on a hinge. 2011 Vogue SE TDV8
Post #593947 12th May 2021 8:22am
Merchy
Just take it out then you can see from the back what is happening with the mechanism when you operate it, sounds like the spring clip is not seating correctly.or the bracket is worn.
Post #593963 12th May 2021 10:11am
omg!
Scotland 2011 Range Rover Vogue TDV8 Santorini Black
Mine is the same.
It won't stay open, there is no resistance when opening it or closing it. When closed there is nothing keeping it closed and it just flaps around when you touch it.
Post #593976 12th May 2021 12:02pm
See if this helps, a video of it opening, the silver part is a spring that is retained at the back of the black plastic bit, I expect the plastic has broken, mine has cracks where the arrow is in the photo so will probably fail soon...
 Pete
Post #593979 12th May 2021 12:16pm
mark towill
Canada 2008 Range Rover HSE 4.4 V8 Stornoway Grey
Yes, you must unscrew the cap and at the threaded end of the cap is the male peg that goes into the top of the inside fuel door. this ingeniously holds the door open while not scratching the paint of your RR. While we are on the subject does everyones fuel door lock still function? Mine never worked ever since I owned it!
Post #594459 17th May 2021 3:23am
Merchy
For the fuel filler cap locking, maybe the small piston is seized, try some penetrating fluid, failing that the solenoid or whatever activates it could have failed. I always use some silicone grease on mine.
Post #594466 17th May 2021 8:26am
If that is all that holds your door open then yours is broken as well, the door has a distinctive held open position, it does not just flap about until you put the cap in it's retainer....
Locking solenoid is not a common failure, easy to swap though if some spray doesn't help... Thumbs Up Pete
Post #594481 17th May 2021 10:35am
stevepen
I've ordered one in Stornoway Grey from eBay complete with all the mechanism. I can compare them and see if something has come away from mine. If not I'll just swap them over. Only £19 and I'll have a spare door too. 2011 Vogue SE TDV8
Post #594506 17th May 2021 2:37pm
stevepen
Sorted it today. The used one of eBay arrived and once I removed the original one you can see the broken piece of plastic on the back. Doesn't look fixable. Swapped the hinges over and all good now.
 2011 Vogue SE TDV8
Post #594614 18th May 2021 3:41pm
There's yer problem...
Glad it's sorted... Thumbs Up Pete
Post #594646 18th May 2021 7:59pm
Merchy
You don't see that very often Shocked a cheap fix for a FFRR problem Thumbs Up
Post #594647 18th May 2021 8:01pm
omg!
I ordered a new hinge and spring for £18 delivered.
Took 5 minutes to fit and now the door stays open and clicks shut.
Post #594822 20th May 2021 4:53pm
