![]() | Home > Technical (L322) > Had a bit of an accident |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8781 ![]() ![]() ![]() |
Won't turn over, or won't start...?
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 ![]() ![]() ![]() |
Won’t turn over mate, lights on dash, but nothing if I press starter !!
Just took the under tray off, axle stand has put a big dent in starter motor, expensive lesson learned me thinks |
That's probably it then... |
What type of axle stand broke? Make, loading ? Image ? .
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 553 ![]() ![]() ![]() |
I used some Halfords 2t axle stands the other year to do a job on my old L322 and noticed straight away that the foot of one of them started to splay. very quickly put it back on the ground and bought some 3t stands. Drives:
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 226 ![]() ![]() ![]() |
Frightening.
mandelbug Member Since: 06 Mar 2017 Location: London Posts: 40 ![]() ![]() ![]() |
Sticking wheels under the car is a trick rally drivers use, suspect a few have had their car fall of the quick jack on rough terrain in a welsh forest!
I think the ground we were on had something to do with it, the stand sank into the concrete, causing the fall.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
so lucky that you wernt underneath it at the time...hope you sort it soon. |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2717 ![]() ![]() ![]() |
Aye Stan, that's exactly what scares the bejesus out of me when using stands & jacks etc. Like the time i was changing a wheel, lowered the car, hadn't put the handbrake on , cue the car rolling towards the garage ( my drive is on a slight slope) I panicked, and thankfully I still had my long half inch bar on the last nut, which jammed into the drive , stopping the whole car .... could have been worse.. |
I have always thought these plastic ramps seem a good idea for non wheel related work, but havent had any experience with them and they seem a bit low.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
As I jack mine up on tarmac, I always put substantial pieces of hard timber under the trolley jack and axle stands, to spread the load. Also where one axle stand would do, I always use two, belt and braces style, so to speak |
