Home > Technical (L322) > Mirror welcome lights
dougie
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
Im hoping someone can help point me in the right direction.
the RR is new to me and have only owned it a few days, but my welcome/puddle lights wont turn on when opening the car, I have changed the bulbs and checked all the fuses that I can find which relate to the lights, but nothing. All other bulbs in the car work, but neither of the mirrors. Am i missing something?
The only thing i can think of now s actual wiring, but happy to check a few more fuse locations if anyone can help pin point them for me.
Thanks everyone
Post #594248 14th May 2021 3:47pm
DrRob
Welcome!
Fuse? Not sure if it has its own Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #594249 14th May 2021 3:51pm
Merchy
https://fusesdiagram.com/range-rover/fuses...-2012.html
Try the above for all fuses and relays, besides the fuse, it could be the puddle lamp relay that has failed.
Could not see a fuse listed for puddle lamps, but there is one called 'approach lamps' ?
The puddle lamps should come on with all the interior lights when you press the key fob button to unlock the car.
Hope this helps Thumbs Up
Post #594265 14th May 2021 8:12pm
Welcome to the club Dougie...
The mirror lamps don't come on with the interior lights per see! They illuminate when you unlock the car and they time out really quickly...
So, start the car and run it for a min or two, then lock the car and let it go to sleep for them mins or so... Then you will be able to see if they work when you unlock the car...
Alternatively, remove the front door cards, cut the wires to the mirror lamps and join the wires from the lower door panel lights... They will then work every time the interior lights come on Thumbs Up
Post #594284 14th May 2021 11:50pm
bluebottle
United Kingdom 2012 Range Rover Vogue SE TDV8 Buckingham Blue
Can these be coded with an IID tool? 2012 L322 TDV8 Vogue SE: Buckingham Blue
2005 Defender TD5 110 XS: Cairns Blue - Gone but not forgotten
Post #594287 15th May 2021 12:36am
Question Coded Question
Post #594319 15th May 2021 11:09am
bluebottle
Can the timing and behaviour be altered with an IID tool? 2012 L322 TDV8 Vogue SE: Buckingham Blue
Post #594320 15th May 2021 11:17am
No sir...
Post #594328 15th May 2021 2:22pm
