![]() | Home > Technical (L322) > Rover All Comms - First Look |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
i got a pre-production unit ..they are on sale from the 25th rob. ... - .- -.
InVogue Member Since: 03 Nov 2010 Location: Cheshire Posts: 57 ![]() ![]() |
Another idea/request - enabling of "triple-flash" indicator function |
jonminns Member Since: 07 Mar 2011 Location: Leicestershire, UK Posts: 155 ![]() ![]() ![]() |
+1 on the 3 flash 'lazy' indicators, that'd be great! |
i'm hoping that the developer of this programme is following this thread and is taking these suggestions on board..
Confused - what is this tripple flash you speak of? ![]() |
i think its when you are travelling down the motorway and you want to overtake, you flick the indicator up/down and the indicators flash three times... ... - .- -.
Is that an option on the RR?
dont know mate, i dont indicate anyway so no big deal for me.. |
dont think so..it sounds like the 'mechanics' of the door are faulty.. ... - .- -.
andylouca Member Since: 07 Apr 2011 Location: Bucks Posts: 3 ![]() ![]() |
cheers scarey, I only asked because when I rang up one of the dealers to get new latches they said it may well not be the latch but would be worth checking out first. All the cables etc are working as they should be (if you remove the trim form the window you can see into the door) I can see the latch being operated but the door will not open. My only hope is I can operate the lock/unlock function via diagnostics or at least prove it is the latch before smashing it.
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Triple flash of the indicators has been on RRS/D4/FFRR since about 2008/9 - have had it on both my RRS's and it's on my current 2010. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
defo sounds like the mechanical side andy, something isnt engaging properly to open the door... the RAC is a clever bit of stuff although some of it is still in development, i keep hoping to get faults come up so i can clear them ..one change i have done is to switch off the steering column so it doesn't move when you turn the ignition on, bound to save wear on the motors... ... - .- -. Y. O. L. O. . |
its encouraging that its on a later model ,hopefully it can be activated on the 2002/2005 models.. ... - .- -. Y. O. L. O. . |
My steering column doesn't move when i put the ignition on or off ..... yet it does work as it is programmed into the drivers seat memory if SWMBO has driven it ... |
