![]() | Home > Technical (L405) > Charging system fault detected |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 781 ![]() ![]() ![]() |
Do you know what the state of your battery is? If the car had been standing for a while before you jumped in, the battery may have been a bit low. These vehicles sometimes throw spurious errors when the battery voltage is low. Kev
Rufus135 Member Since: 16 Apr 2021 Location: Cheltenham Posts: 15 ![]() ![]() ![]() |
The garage put a new battery in it when I picked it up a month ago. I thought something was strange this weekend when the stop start wasn’t working. |
AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 400 ![]() ![]() |
It could be that the Gateway Module needs updating, mine did exactly the same thing. Should still be under manufacturers warranty, call LR Assistance out, they can check the battery and update the module if necessary. I don’t think you’ll have any problems getting to Taunton once on the move but the error may need clearing. |
Sounds like good advice thanks |
