![]() | Home > Maintenance & Mods (L322) > Cleaning light coloured rear loadspace cover |
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2721
I used a vanish sponge on light tan then a light grey one, stuck it out in the sun to dry , came out great. |
| hlarry Member Since: 30 Jan 2021 Location: London Posts: 22
Thanks but I can't find "Vanish sponge" as a product. Do you mean using Vanish solution with a sponge?
| verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952
I have used a carpet cleaner (sprays warm water with dedicated soap and sucks it right away)
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8134
If its just dirt, any mild soap & pressure washer - not max setting and close range, but they are surprisingly resilient |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
I too have used Vanish, as a foam and left then worked in with a damp cloth that you rinse out in clean water as you go.
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
Cif and a nail brush and a hose down cleaned mine. |
| Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238
Just to give everyone a good laugh, at my expense, saw this thread earlier on and thought, les problemos, mine is nice 'n' sparkly, as I always look after it religiously. |
Oh dear |
Fresh mud - just stand it up against a wall & hose it down - I use a pressure washer- then leave to dry |
Is this where I don’t suggest you do that to the cat? 🤣 2011 Range Rover Vogue SE 4.4 TDV8
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
Yep, they are tough as old boots. my old ivory one was filthy when I bought fatty offroader, I used neat TFR, scrubbed it, then jet washed it off pretty close and it came up like new...!!!
Pressure washer V's cat |
