![]() | Home > Technical (L322) > L322 2011 Towbar electrics |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1197 ![]() ![]() ![]() |
Dave
Shovie Member Since: 04 May 2021 Location: Wickwar area Posts: 14 ![]() ![]() ![]() |
Thanks Richard,
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
I would start with the socket.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Get a test lamp or a meter and check between the following pins and the chassis. Pin 7 L.H. Side lamp, Pin 5 R.H. Side lamp. Both should light the test lamp or show 12v on meter between the pin and the chassis. If they show live then do the same but this time instead of the chassis connection, connect to pin 3. Pin numbers are correct for both 7 pin and 13pin trailer sockets and of course you need the side lights on when testing. BMW i3 Electric Car
Thanks all,
PM Sent BMW i3 Electric Car
Many thanks for the PM, exactly what I need. How can I physically find the location of trailer ECU D221? Is there a component map?
Hi,
Well done that man! BMW i3 Electric Car
