Home > Technical (L322) > Is this normal??
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Is this normal??
Hi
I noticed some oil in coolant.
Is this normal??
 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #594584 18th May 2021 10:17am
Dolphinboy
Oil cooler fail. a common fault in this engine. Either replace the O rings or better still, if you can afford it, change the oil cooler, as they can go (i.e. the gasket fails) inside.
Lots of info on here. Search is your friend.
Post #594596 18th May 2021 12:32pm
umitbat
Thanks mate. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #594613 18th May 2021 3:38pm
Dolphinboy
You will need to get your coolant expansion bottle and system flushed out or may need to change the bottle as well (£70) if it is stained with oil. My guy used FORTE Bio degreaser (only £17) and 2 hrs labour to flush. 3 hours for the Oil cooler change.
Post #594663 18th May 2021 10:31pm
umitbat
Great info thanks!!! 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #594664 18th May 2021 10:49pm
umitbat
They checked the cooler it is ok.
It is not oil.
It seems it is because i put pure antifreeze and that is the reason.
I did not know i must mix with water. I thought it would mix in there;)
We will try to empty tank and look for a week.
If not successful change the tank. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #594675 19th May 2021 8:21am
I've put neat antifreeze in loads of times on loads of different vehicles, always do when topping up a bit, never had any problems, it always mixes either straight away, or after it's been running a while...!!
I think they don't want the cooler change job maybe....? Pete
Post #594702 19th May 2021 11:50am
umitbat
I really have no idea.
Anyway after a week i will change the coolant.
He said antifreeze is different although i used red and it did not mix with old one and removed some sticky rusts. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #594704 19th May 2021 12:03pm
Dolphinboy
If you mix OAT (red) coolant with a non-OAT type (blue?) then I believe they can react and "gel" up?
Post #594706 19th May 2021 12:40pm
Merchy
Put a clean white absorbent, lint free cloth into the top of the coolant tank then slowly immerse cloth into a bowl of warm clean water, then you will see if any oil floats to the top. Probably not in your case. Thumbs Up
Like Haylands, if it is just a little top up, I always add neat anti freeze to the system, it doesn't take long to mix in.
If you are getting a lot of 'rusty residue' then it may be a good idea to change / flush the system, if just a little then just keep an eye on it.
Post #594707 19th May 2021 12:43pm
umitbat
That surprised me because old and new are both red.
Something was not right about new red antifreeze maybe!
Yes I tried white cloth check yesterday and there was no scary blackish looks.
After a week if it is ok we will flush if not also a tank change. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #594713 19th May 2021 2:10pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
As an aside, I've always used OAT orange/pink colour in mine. Was browsing in Halfrauds (SWMBO was in Dunhelm mill looking at stuff I'm not interested in) the other day, when I had a look at the in-house book that tells you what type of antifreeze to use. Was a bit perturbed to see that the other type (blue) was recommended for mine! 😳 Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #594756 19th May 2021 8:45pm
umitbat
I will flush the system but Coolant low fault never disappears now.
Can bad coolant conditions cause this? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #595448 27th May 2021 7:31am
umitbat
I changed the coolant.
I used the return pipe that is at the top of the tank.
First water coming out was terrible but it never got clear as fresh water.
I added water continuesly with hose for 5 minutes then added coolant till water coming out turned pink.
But still coolant is not clear as used to be.
Is it because i did not use big hoses or radiator tap to empty existing coolant?? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #595471 27th May 2021 11:53am
umitbat
Is it possible to remove sensor under the water tank?
I think sensor is too dirty to detect. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #595503 27th May 2021 1:56pm
