![]() | Home > Maintenance & Mods (L322) > Light cluster water woes |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
I used to get that in my fatty off roader after wading, I drilled a very small hole in the bottom to let it drain out...
| Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3278
there is lots on this forum ref this. do a search. Mine had a slight leak in the top right, invisible to to see with the eye. sealed with glue and dried out.
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
As above, drill a small hidden hole to let the water out then reseal the whole light and refit.. |
| RRover Member Since: 17 May 2021 Location: Sussex Posts: 278
Thanks for these tips all. Yes I have been searching and have happened across a few posts almost similar in nature.... Just wanted to be a tad more specific and also some of the closely relevant posts are quite old, and we learn different things as time goes by...
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3962
I did what Craig suggested drilled the holed drained the water and resealed, surprisingly (to me at least) the water was getting in though the screw holes on the back not the seams. How do I know I injected (with a syringe) some soapy water and the blew it out with a compressor and watched for the tell tale bubbles. I left the hole as a vent but no water got in through it. Geoff |
Interesting yet again, ss... I guess you mean the four big Philips screws at rear of light cluster?!? If so, I would not have suspected any water ingress from that area!!! On mine this area is or appears bone dry - whereas the inner side wall seam/join between black body and clear perspex lens, which is hidden when hatch is closed, has damp and moss like similar at car window rubbers during winter?!? Looks like I'm heading towards the tiny drilled hole - so I guess start with 1mm slow drill bit size and increase bit size until water evacuates! Then plug!
Mine was/is an L405 so might not be the same but I think the rational is the same, get the water out and seal everything |
Wrenched (that lecky connect plug is so damned tight - |
When you think all the condensation has gone, seal it in a plastic bag over night, that will show if any is left... |
Gotcha - that makes sense!!! Saw another vid on-line where the cluster (sounds like something existing way out in the deep cosmos |
This was how much condensation was left inside light cluster after slightly prising join/seam apart with screw driver and letting about an inch to inch and a half of water gush out. Dried off indoors for several days, then sealed with clear silicone to the hatch, and lower section seams edges.
