Home > Technical (L322) > Steering wheel no longer lowering automatically
garyRR
I have a 2006 3.6 Vogue and my steering wheel has stopped lowering/going up when turning the ignition on and off.
When I put the key in, the wheel will jolt slightly as if it's about to lower then, do nothing. Most of the time, it does retract when I remove the key but, not every time and sometimes, it goes down to its lowest setting instead of up.
The steering wheel still adjusts electronically when using the lever however, first pull and it does nothing. Second pull and it then adjusts. I used to have to just pull it the once to adjust. So, I presume there is a position sensor somewhere which has failed?
Does anyone know where it is and the part number and point me to a guide to the replacement? 2015 Range Rover Autobiography 4.4 SDV8
Post #594658 18th May 2021 9:38pm
Henrik07
Norway 2007 Range Rover Vogue TDV8 Santorini Black
Hi.
I'm not saying this is the case with yours, but your symptoms are identical to what I had a good while back (in addition to some other stuff). Have a read here:
https://www.fullfatrr.com/forum/topic47667.html
The dealer recommended a new steering column, so I'm glad I did some experimenting first - it wouldn't have solved a thing.
Cheers!
Henrik
Post #594715 19th May 2021 2:36pm
garyRR
I'm not sure UK versions had a FBH fitted.
There's certainly no option or remote for it in my car and the timed climate just seems to run the fans and nothing else. 2015 Range Rover Autobiography 4.4 SDV8
Post #594750 19th May 2021 8:21pm
bluebottle
United Kingdom 2012 Range Rover Vogue SE TDV8 Buckingham Blue
Mine has a FBH, I haven't tried it though I have the remote. 2012 L322 TDV8 Vogue SE: Buckingham Blue
2005 Defender TD5 110 XS: Cairns Blue - Gone but not forgotten
Post #594762 19th May 2021 10:22pm
Merchy
Ditto as Bluebottle says - My 2006 has the FBH, but never used it.
Before you spend any money, have a look at the below links
&vl=en-GB
Also, if you do not possess a 'reader tool' get it checked out for any codes before taking action. May be lucky and have dodgy contacts or something - especially as it will move at times as designed. Fingers crossed Thumbs Up
Post #594767 19th May 2021 11:20pm
CongoBoy
South Africa 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
As above. I disabled mine via my GAP but it's the steering column can still be used via the column control. 2005 FFRR SC Java Black with Overfinch Exhaust (UK)
2008 D3 HSE Stornoway Grey (UK)
2008 D3 HSE Izmir Blue (ZA/Zimbabwe)
1995 D1 300 Tdi (Zimbabwe)
Post #594768 19th May 2021 11:28pm
garyRR
I have the IID tool, spent a load of money on it and to be honest, I don't think they're much use when it comes to diagnosing problems.
Old Range Rovers have a) very complex electronics and, problems can manifest a symptom opposed to the root cause b) they grow errors over time, as the resistance of copper increases and things get old so, you get lots of false negatives
So, I've never found the iID tool of any use if I'm honest. You always have to identify manually anyway.
Is there a position sensor? Given my steering column works, I'm inclined to say it's either the little microcontroller on the unit that controls the steering column or, a position sensor (if the car has one). 2015 Range Rover Autobiography 4.4 SDV8
Post #594769 19th May 2021 11:31pm
Merchy
Just found this, may give you some clues / pointers, hope this helps, I know just how bloody infuriating these cars can be. Censored Big Cry
https://www.landyzone.co.uk/land-rover/ste...tures.3120
Post #594771 19th May 2021 11:50pm
As for an IID tool not being useful I have to disagree, used mine dozens of times on both fatties and would be lost without it, you have to know how to interpret readings and specific fault codes but that is where this forum and the internet help, it just takes some time on line... Thumbs Up
I think the drivers seat memory ECU stores the info for the position of the column I don't think there are any position sensors I think it does it with smoke and mirrors (ie, I don't know how) There could be faults listed for it, it could need resetting in the CCF and you could also try a battery disconnection to reset it... All cheap and worth a try... Thumbs Up Pete
-Click here for Thread-
Post #594772 19th May 2021 11:52pm
Merchy
Think the same as in the above post, all I can add now is that a huge number of operations / commands are routed through the BCM ( Or BCU as some call it ) so reading any codes could be advantageous, prior to pulling bits out or spending money.
I have an Icarsoft reader specific to JLR, whilst it is a good tool, it is not as good as the aforementioned device.
Post #594775 20th May 2021 12:55am
garyRR
I think you're missing the point of my remark.
The IID tool I find is not great for diagnosing. Because the electrics in these cars are so complex and there are numerous controllers, there are also umpteen fault codes. When the car chucks up a fault code or fault codes, these tend to be symptoms opposed to the root cause of an issue, requiring further analysis / ruling things out one by one anyway. That's why I've not foind it great for diagnosis. You might think it's useful because it gives a load of codes but, in my experience, you have to go and rule things out regardless, which is what you'd do if you didn't have the tool.
I work on boats and you'd be really surprised at what happens to circuit boards, terminals and cabling. The salty environment highly accelerates degradation in all electricals and it's not uncommon for the resistance of a copper wire to have increased enough that it begins causing electrical 'gremlins' within 5 years. The IID tool will always show a shed load of faults for this reason, as things degrade.
Anyway, if there's no position sensor, it's likely 1 of 2 things. I'll get the multimeter on and testing. My suspicion is that it's the seat ECU, if this is where the wheel is controlled from. 2015 Range Rover Autobiography 4.4 SDV8
Post #594776 20th May 2021 1:41am
Henrik07
I may be wrong, but I think all the V8 diesels have it. Some have the remote and others don't. Its main function is not to let you pre-heat the cabin, but rather to bring your engine up to running temp on a cold day. The fact that you get nothing but cold air on timed climate, doesn't mean that you don't have one - it only means that yours doesn't work, which it wouldn't if it's original and untouched since 2006.
It sits beneath the battery tray if it's there. Access is via the wheelarch liner, but access from above can be arranged by drilling out the captive bolt sort of in the middle of the tray.
As the weather strips under the windscreen and along the top of the bonnet fail, and the drains in each corner clog, water pours into the battery compartment every time it rains. This water is dumped right on top of the FBH, where all the electrical connections are.
Again, I'm not saying that this is your problem, but I urge you to check it off your list. My first symptoms were exactly what you're describing. Not just close, but exactly the same. The rest came along a while later.
I agree on your assessment of IID-tool or other diagnoistic's usefulness for fault tracing on these cars. I don't own one myself, but I've been to dealers and indys for diagnostics and they've only ever hit the mark when it's something engine-related. For wonky electrical faults, it's about as useful as tits on a donkey. In my experience, with P38, L322, Jag, VW and Alfa Romeo, these types of faults are always caused by moisture and corrosion. There must be a logical explanation as to why a semi-shorted FBH would affect the steering column, wipers, central locking, windows and whatever else you can shake a stick at, but plugging a device into your OBD-port is very unlikely to provide that explanation.
This is why, when you take your car to the dealer's for diagnostics and repair, they will always come back with a list of parts which need replacing. These are the parts that the diagnostics list as faulty or unresponsive. More often than not, replacing these parts will not cure the problem, as it usually lies elsewhere. All you get is a bigger bill.
That really bugs me, but I understand why it's so. The amount of time that goes into fault-tracing the electronics of something as complex as a Range Rover, makes it pretty much prohibitive from a cost perspective. Therefore, it sort of makes sense to replace parts first to see if that does the trick. Sometimes it will, either because the part was actually defective, or because the simple act of unplugging the old and connecting the new has re-established a previously broken connection. My sad realisation is that when it comes to in-car electronics, you're pretty much on your own if you're not knee-deep in cash. Thankfully there are forums like this, where someone is likely to have had a similar problem and managed to solve it.
Good luck!
Henrik
Post #594779 20th May 2021 7:43am
Gary...
Once you have the codes you check the W/M and it gives you a workthrough of said fault, yes some are spurious but they will give you a pointer on where to start a lot of the time...
The issue we all face with the fatties is that most parts are sourced from the BMW parts bin, the 322 was virtually finished under their ownership but they never got round to clearing all the faults from the system, subsequently they do come from the factory with a host of faults...
I drowned fatty off roader twice to well over the BCM, it got soaked.... once properly dried out it was fine and is still going strong today, haven't personally seen a problem yet that was from degraded wiring, a few poorly routed wires which work harden and break though......
I can't understand who thought canbus etc was a good idea on boats though, that's why my Hatteras was old school with Detroits ..... Thumbs Up Pete
Post #594789 20th May 2021 10:02am
