Home > Technical (L322) > How to Adjust the Reversing Camera?
TJRL
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
I just had my upper rear-tailgate replaced with a resprayed second hand unit. But the reversing camera is pointing a little bit too low, so I get a great view of the rear window and not as much of the area beyond as I used to!
The bodyshop that did the work were not sure to adjust the camera angle and nor am I. Embarassed
Can anyone point in the right direction before I break something trying? Shocked
Many thanks. 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD Sad
1960 Land Rover SII SWB SW
2020 BMW R1250 RT LE
2021 Triton ST-125 (Monkey Bike)
Post #594806 20th May 2021 2:56pm
kbald
If it's the OEM fixed camera there isn't a way I don't believe. Have they fitted the top of the tailgate that houses the camera back on correctly? Current 2007 TDV8 Vogue Buckingham Blue
Post #594810 20th May 2021 3:44pm
TJRL
Yes it is the OEM camera, but I do not think it is incorrectly fitted. How could I check? 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD Sad
Post #594820 20th May 2021 4:39pm
kbald
You can remove it using the video here.
It should be pretty obvious if it's not fitted correctly though Current 2007 TDV8 Vogue Buckingham Blue
Post #594833 20th May 2021 6:33pm
