Home > Maintenance & Mods (L405) > towbar
aguiness
United Kingdom 2017 Range Rover Vogue SE TDV6 Aruba
towbar
Hi
I am looking at fitting a towbar,
i can purchase the hardware and the elect kit here
https://www.witter-towbars.co.uk/towbar/vi...AyMDEzIC0g
i can also get the wiring kit for 13pin
my question is do you need to configure the car to get it to register
Post #594863 21st May 2021 9:01am
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
I have just had a removable TowTrust bar fitted with the 'plug and play' electrics. They worked immediately without any activation, in terms of indicator repeater lamp, and also disabling sensors when reversing etc. What I haven't been able to get to work is TowAssist as I assumed that 1) I have this and 2) it would 'appear' when reversing when towing.
Not sure if any activation would make this appear, or maybe I just don't have it after all. Not sure how to check.
It's 67 plate 4.4 AB
Post #594870 21st May 2021 9:31am
aguiness
great thanks
i take it with tow assist you mean the camera guiding you to the tow hitch
Post #594872 21st May 2021 9:34am
James W
Yes, the camera works but I expected more options to become available
All of this stuff: https://www.ownerinfo.landrover.com/docume...c/G1943548
Post #594873 21st May 2021 9:37am
aguiness
hi
i think that may be an option, my last one had the deployable towbar the only assist i got was the line guiding you to the hitch nothing else
if that works without any config i think thats as good as it gets
thanks
Post #594874 21st May 2021 9:42am
Yes to get everything working correctly you would A, need a trailer/caravan without LED lights! If this doesn't allow the system to work correctly then B, you would need the diagnostics/CCF files manipulated Thumbs Up
Post #594877 21st May 2021 9:58am
James W
Yeah the lights are non-LED on my trailer and caravan. I can't even get the option to get the camera to zoom in on the tow ball when reversing... So a CCF edit would do that then you reckon?
Post #594879 21st May 2021 10:27am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
The tow electrics will work plug and play, but to get everything IE, beepers disabled and guide to hitch via the camera you need a software update, a good indie who specialise in Land Rover can usually do it for you Thumbs Up
Post #594886 21st May 2021 11:04am
James W
Excellent - will turn up with extra chocolate biscuits at the next service then Thumbs Up
Post #594890 21st May 2021 11:37am
