Home > Technical (L322) > Cracked LH intake manifold
t5pete
Hello all was driving on the motorway tonight and had a pop under acceleration followed by restricted performance.
Had a quick look and ide say it looks like the LH intake has split I was In my best clothes so didn't want to get too dirty and will investigate further on Sunday but would appreciate other peoples opinions or experience.
The 4 hoses have been replaced and inspected tonight.
Thank you
Post #594952 21st May 2021 9:53pm
Dolphinboy
If it is the Inlet Manifold, then it will cost c. £1600 to replace. Mine went on the Pax side and they are a known weak point - LR have had the part upgraded as the originals were unable to take the pressure of the 2 turbos and the flexing caused splits.
Get a high pressure test done for any leaks first. then do a search for "inlet" on here.
Your starter for 10 is here. Good luck!!
https://www.fullfatrr.com/forum/topic43767-15.html
Post #594957 21st May 2021 11:04pm
t5pete
I would say it's most likely to be the manifold thats split as can also hear it with reving, I'll pressure test it and inspect Sunday. That's good news if they have a better quality manifold now do you happen to know the part number for the updated item or is it still LR034993
Post #594958 21st May 2021 11:21pm
Chapeau! Velo
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
I’ve literally just had mine done. LHS too (3.6 TDV8). Specialist says this is now a common problem owing to age and mileage. Mine was a £700 fix with a LR indi using genuine parts if that’s a helpful barometer.
Post #594984 22nd May 2021 12:41pm
Dolphinboy
Pete, I think the number is the same but you could check with Duckworths.
Here are my bills.
Post #595009 22nd May 2021 6:14pm
RRover
2012 Range Rover Westminster TDV8 Causeway Grey
Vindictive Added Tax is a killer these days...
We all need to become politicians to avoid such calamitous things...
Big Cry
Post #595010 22nd May 2021 6:29pm
t5pete
Here are my bills.
Brilliant thank you
Post #595032 22nd May 2021 8:21pm
t5pete
Unfortunately the issue with plastic looks like it's most common on the lhs
Post #595034 22nd May 2021 8:36pm
t5pete
Definitely the manifold
Post #595099 23rd May 2021 4:26pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Those look like replacement silicone connecting sleeves and possibly the jubilee clamp tightened a little too much placing extra strain on the plastic welded joint?
Post #595109 23rd May 2021 6:35pm
t5pete
Yes there the replacment hoses I changed the seam where the manifold has failed shouldn't be affected by the hoses and definitely not overtightend, to be honest I've noticed since getting our car there has always been a missing of oil round the lhd manifold area so been failing for a while by the looks of it
Post #595110 23rd May 2021 7:07pm
Dolphinboy
Removal is quite a protracted affair apparently as the injector lines need to be removed hence the labour cost.
Post #595113 23rd May 2021 8:00pm
t5pete
I can definitely see a fair amount of labour.
I've read through the manual and looks straight forward just a ball ache and injector no8 fouling on the inner wing for the removal so the engine needs lifting and battery side cover removed to gain access for removal, others have split the solenoid from the injector but my luck it would end up breaking so will just lift the engine.
Email sent off to Robin at duckworths for the parts and will post pictures in my thread once done.
Post #595135 23rd May 2021 11:30pm
