Home > Technical (L322) > Can someone check this on a 3.6 tdv8 please.
RRTDV83.6
United Kingdom 2007 Range Rover Vogue TDV8 Santorini Black
Hi my tdv8 has a massive lag when driven or even when revved on the spot.
I have noticed it is much more responsive on the throttle, being revved in neutral with the electric handbrake off and in low range than in high range, can anyone confirm this is the same on theirs?
Its like some sort of torque limiter and I was wondering if its a software issue. Just to note it is worse then ever with the handbrake on! Cheers all.
Post #592382 25th Apr 2021 9:48pm
Check you intercooler hoses, plenty of info on how to in the wiki. The top ones need to come off and be thoroughly checked.
I can’t quite see what you are getting at with the revving up?
So if you basically sit with it in, special programs off, high range, neutral, left foot on the brake and hand brake off... - it revs up ok?
If you then just put the hand brake on but still in neutral - it won’t Rev as well and feels laggy. This shouldn’t make a difference by the way.
Double check you have the special programmes turned off. There is nothing that can't be fixed with a hammer😜😜
Post #592545 27th Apr 2021 5:56pm
mjdronfield
Yeah, as above. First initial knee jerk thoughts are some sort of throttle mapping issue. Not sure how hand brake should affect it though......
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #592550 27th Apr 2021 6:42pm
RRTDV83.6
Thanks for the reply, I have recorded what happens, it really does seem like a throttle map issue. Almost like a restricted performance mode. No fault codes, no boost leaks, checked with a kit. Egrs are blanked and mapped out.
Live data all seems to check ok and equal on the air flow and map pressure.
I will post the video on you tube and post the link. Many thanks again guys.
Post #594035 12th May 2021 6:14pm
RRTDV83.6
https://youtube.com/shorts/dhOuixISjqY?feature=share
You tube video of the problem.
Any help appreciated. Cheers.
Post #594059 12th May 2021 8:32pm
RRTDV83.6
Hi, what do you think of the video? Cheers
Post #595044 22nd May 2021 10:40pm
