Home > Maintenance & Mods (L322) > 60,000 mile service cost L322 4.4tdv8 ? |
RRover Member Since: 17 May 2021 Location: Sussex Posts: 278 |
Sounds OK-ish to me. I just did my 60,000 mile (62,000) service few weeks ago with the Thatched Garage Land Rover outfit near Lewes and that was around the same price. My bill was a £100 more, as I'd asked for a diagnostics test, to clear some alerts codes that keep popping up, and they didn't clear them, or say anything other than I was driving the beastie a bit too slow, and should clear it out on faster runs.
24th May 2021 9:04am |
TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 196 |
thanks, good info.
24th May 2021 9:07am |
I might try turning my alert code warnings off completely...........
24th May 2021 9:12am |
The garage I took it to for MOT (RAC Approved) said my FF needed to go to Range Rover as there were too many fault codes that they could not deal with or had or something along those lines... |
24th May 2021 9:25am |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1368 |
Get yourself an IID Tool and you can read and reset codes yourself and much more. 2017 4.4 SDV8 Autobiography
24th May 2021 11:11am |
Did the forum arrive at any particular diagnostics tool plug-in? I know a few have been talked about. Although I paid for the LR/RR '''specialists''' a week or so ago to clear my three codes that have been a regular showpiece for two years now, they did not clear them. And they said they had all the main-dealer space/warp time/travel diagnostics gear imaginable...
24th May 2021 11:48am |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 207 |
Anything with a Land Rover badge, you need to get yourself a iid tool. |
24th May 2021 12:29pm |
Looks that way - although if LR diagnostics can't clear codes how does the plug-in achieve it? |
24th May 2021 1:26pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4298 |
Just get yourself a GAP IID Bluetooth from Island 4x4 or Bell Auto Services. It will pay for itself in no time.
24th May 2021 2:11pm |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
You mention that you have 3 codes that won't clear, did you get any details of these?
24th May 2021 3:13pm |
Yes the IID looks to be a must, maybe for TeeMyob AND myself. A few examples have been added here, with thanks. My personal three repeated code/s alerts are: 1/ Emergency brake assist not available... 2/ HDC not available system fault... 3/ Stability control not available - drive with care... Had three checks on these alerts (regular over 2 years and now nearly every drive so I simply OK them) and the mechanical items involved in these code alerts are AOK it seems... Will certainly look into the IID units though... |
24th May 2021 4:22pm |
Yeah just mentioned to DrRob my codes, and they have been checked but on-going, and mechanical relationship parts to these alerts are AOK it seems... 1/ Emergency brake assist not available... 2/ HDC not available system fault... 3/ Stability control not available - drive with care... Cheers for help... |
24th May 2021 4:26pm |
Thanks for the replies.
24th May 2021 7:28pm |
The main dealer prices tend to be around the prices you mention. Harwoods quoted me around £750 for the same service I had my local LR '''specialists''' do for £400, yet when speaking after paying for the service they said a full service was around £750, which confused me, as I had booked my beastie in for a FULL service when they quoted me around £400.. It seems that the basic or interim service involves mainly the oil and oil filter changes, with maybe a pollen or cabin filter (which looks around the easiest of things to do yourself - just un-clip and clip up again after replace and it's right under your wipers) and maybe they'll check the tyre pressures. A lot of money for mostly an oil change but there is a lot of it. Half way through the service year I get someone I know and trust to change oil and filter right before my very eyes - as I personally don't trust that all outlets actually change your oil... I prefer changing the oil twice a year anyhows - in any of our vehicles... Even the misses' wee retro Fiat 500...
25th May 2021 6:17am |
