![]() | Home > Maintenance & Mods (L322) > WHEEL LOCATING PINS |
its the same thread size [14x1.5] but if you are fitting the 2002-2005 OE wheels with the 20mm size shank nuts then the locating pins will be to big ..
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
That’s what I was wondering to be honest.... I thought they were the same fitment... just the wheel bolt washer angle that was different, and the pin doesn’t have that on, so should be the same?
your 'now' wheels fit cos the old pins are slightly smaller in diameter? ... - .- -.
Stan, my pins are 20mm día so you are probably right but why would you manufacture a bigger día pin just because the wheel hole was bigger.
i agree...i dont know whether the newer pins are 23mm or like your 20mm ones.. ... - .- -.
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 327 ![]() ![]() ![]() |
Can someone measure the 03-05 pins and send me the details please.
I'll measure them in the morning for you. |
Here you go. |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
nicedayforit - Nice info and drawing. Thank you, it will save me the job of measuring up. I will take the drawing to sea with me to make a set, or be lazy and tell the fitter to make them up for me when he is not too busy |
Thanks from me also nicedatforit. |
