Home > Maintenance & Mods (L322) > 60,000 mile service cost L322 4.4tdv8 ?
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Do the oil change yourself, it has to be one of the easiest you'll ever do as it's all done from the top of the engine. You'll need to get a vacuum device (plenty available at reasonable cost) oil filter is easy to access too. Thumbs Up 2011 TDV8 Vogue SE
Post #595263 25th May 2021 7:37am
RRover
2012 Range Rover Westminster TDV8 Causeway Grey
Must admit I stopped doing my own car services once we got a Freelander in 2000, mostly as peeps do ask for dealer stamps on the service books, plus the vehicles do feel extra potent right after a certified LR/RR dealer has done a service... probably they add something to injectors or fuel to make you think so... Laughing
Mostly this time round I was considering parting with it this year, and so wanted the LR/RR stamp on the service book. I just sorted out the water in the rear light cluster though, so I'm pleased with that at least... Rolling with laughter
I know that most services for these beasties on the tube of you at least have the oil exiting via the sump plug, and my mid service yearly oil changer does that also.
Good that you get down and dirty though...
Still awaiting a new stop-start button which handily is a 5-minutes job also... Thumbs Up
Post #595268 25th May 2021 8:05am
TeeMyob
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Thanks.
I will do in-between LR Schedules when the milages go up. I have and oil filter and did have oil, but used it on my other cars. I have a Hymer Motorhome, An MB Sprinter van, two Toyota Previas and an Audi. I carry out the oil services on those.
May I ask what oil you use Denni?
Post #595333 25th May 2021 8:07pm
TeeMyob
Yes, I have chosen Land Rover to do the Job.
Their quote is not much more than the independents.
People look for Main Dealer Stamps when shopping (I may be selling soon).
I can walk from/to the LR Garage.
Post #595334 25th May 2021 8:09pm
dennij
@TeeMyob, I purchased my oil from a company called Smith & Allan after a recommendation on here
Smith & Allan Momentum C1 F 5W-30 - Fully Synthetic Engine Oil - ACEA C1 Low SAPS Ford WSS-M2C934-B 2011 TDV8 Vogue SE
Post #595353 26th May 2021 7:32am
TeeMyob
Thanks @dennij
Post #595425 26th May 2021 8:42pm
TeeMyob
Thank you
Post #595427 26th May 2021 8:42pm
TeeMyob
SO!
My Car went in today!.
60,000 mile service
It came back with this advisory sheet. I will point out it passed the MOT a couple of weeks ago. Since then its covered 200 miles.
Post #595563 27th May 2021 9:23pm
TeeMyob
I had all 4 discs and pads replaced today. £500 inc VAT
Post #595688 28th May 2021 7:58pm
Rob99
I'm guessing not at the LR dealer......... Whistle Whistle 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #595699 29th May 2021 12:12am
TeeMyob
Very Happy
NO
Local Specialists
I had seen some JLR Original Discs on Ebay £80 a set but would take a time too get them, so.
The specialist fitted these
https://www.apecbraking.co.uk/Products/Discs.aspx
Post #595718 29th May 2021 9:23am
