![]() | Home > Technical (L322) > Gearbox - is this normal, or ongoing paranoia? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
I get a small clunk sometimes into reverse. Life’s too short to worry about it. Press the brake pedal harder next time |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 250 ![]() ![]() ![]() |
Always have the EPB engaged before selecting R/D and as Rob. L322 3.6 TDV8 Vogue. 07MY
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 ![]() ![]() |
Most likely what you're hearing is the backlash in the drivetrain being taken up. Conversely, if the drivetrain is under tension, e.g. if you're parked on a steep hill, shifting out of Park releases that tension and you will get a similar symptom. |
RRover Member Since: 17 May 2021 Location: Sussex Posts: 278 ![]() ![]() |
Yeah mine does that - and my drive is on a slope so you have to ready your nerves. |
