Home > Wheels & Tyres > L405 Turbines. Are these genuine?
kungfupanda
United Kingdom 2014 Range Rover Vogue SE TDV6 Mariana Black
Going to have a look at an L405 Vogue SE tomorrow. From this picture, can anyone tell if the wheels fitted are genuine?
I've read the wiki on these but can't tell with my untrained eyes!
Thanks in advance for any tips.
Post #595347 25th May 2021 11:23pm
Rob99
They don't look quite right for turbines.
Genuine ones are diamond cut and those spokes look a bit "fat". One spoke should be very clearly thinner than the other.
Do you know what size they are? I think genine turbines were 21 or 22", never 20's. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #595348 25th May 2021 11:45pm
kungfupanda
They're 22".
The spec list on Autotrader lists one of the options as 22" turbines. Perhaps they've had a standard refurb with no diamond cut faces.
Post #595349 26th May 2021 12:00am
I think they are genuine, but as above - have been re-finished in silver - none came from the factory finished like that, but a diamond cut refurb is more expensive and a lot of places can't even do it.
It does look like the spokes are slightly different thicknesses - it's more obvious with a diamond cut face, but if you look carefully....
It also depends on the angle - if you look at the spokes here, they look thinner & fatter at different angles.
Post #595355 26th May 2021 7:56am
i think the only sure way is to have a look on the inside of the spokes to confirm the LR product codes.. ... - .- -.
Post #595356 26th May 2021 9:01am
Before you drive it ask them to please put the right number of wheel nuts on the wheel...... Whistle
As Stan says, best way to tell is to look on the back.... they seem to have tpms though so chances are decent.... There is nothing that can't be fixed with a hammer😜😜
Post #595670 28th May 2021 5:06pm
kungfupanda
Got a full powder coat and diamond cut refurb undertaken to my wheels. Really happy with the results.
So I’m happy that they are genuine. It seems the selling garage just undertook a cheap silver refurb rather than an OEM style diamond cut finish.
Post #603522 11th Aug 2021 7:42pm
very nice Thumbs Up ... - .- -.
Post #603523 11th Aug 2021 7:45pm
TJH1985
Thumbs Up very nice indeed! Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #603530 11th Aug 2021 9:03pm
kungfupanda
Thank you for your positive responses gents.
I’ve seen some shocking refurbs out there such as this on Ebay!!
Luckily the guys I’ve used have managed to keep good definition all round.
Post #603604 12th Aug 2021 2:38pm
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
Shocked They have gone a bit mad with the diamond cutter. Set at 10mm instead of 1mm Rolling with laughter Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #603649 12th Aug 2021 9:14pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
[quote="kungfupanda"]Got a full powder coat and diamond cut refurb undertaken to my wheels. Really happy with the results.
Out of interest what did the refurbishment cost? I’m just going through the process of getting my wheels tidied up.
Post #603703 13th Aug 2021 1:53pm
kungfupanda
£440 for a drop off service. They had the car, removed wheels, took the tyres off. Full acid strip down, repair any kerbing then powder coat and diamond cut followed by lacquer. It took a total of three days.
I’m up North though so things might be a bit more expensive down South.
Post #603730 13th Aug 2021 9:49pm
Andy S
Thanks. I’m waiting on a price from a trusted body shop locally but what I’m after is pretty much what you described
Post #603759 14th Aug 2021 12:41pm
kungfupanda
I’ve had quotes of up to £720 from The Wheel Specialist to £320 from a back alley place. Anywhere around £500 should be fair.
Post #603769 14th Aug 2021 1:26pm
