Home > Technical (L405) > L405 4.4 2013 - huge coolant leak - diagram
albertocsoares
2013 Range Rover Vogue SDV8 Siberian Silver
Please help me. Huge coolant leak from the back top of engine, car in the mechanic, could you please post a Cooling Diagram
Did not find any oil in the coolant, is it possible to be the oil cooler gasket in this case?
Have also a small oil leak, looks like from the 2 o-rings
Post #595553 27th May 2021 8:17pm
theres a workshop manual download link in the wiki.. ... - .- -.
Post #595562 27th May 2021 9:12pm
knwatkins
Common problem on the 4.4. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #595568 27th May 2021 9:44pm
albertocsoares
Thank Stan, I checked all the files on the L405 2013 - (Work Manual) and did not find the Cooling Diagram, have you ever seen it on the documentation?
Thank you!
Post #595578 27th May 2021 11:23pm
AnotherMutley
It’s definitely there, looked at it recently, there’s everything, capacity, testing procedures and diagrams.
Post #595579 27th May 2021 11:31pm
Quite common on a 4.4 sir Rolling Eyes Thumbs Up
Post #595581 27th May 2021 11:36pm
Kot
PM me 2018 SE SDV8 4.4 Byron Blue
Post #595597 28th May 2021 8:26am
albertocsoares
I will change the oil cooler gasket today and pray it solves, if not my mechanic wants do pull the engine down as he does not have access to work between the engine and the car panel, what do you think about his plan?
Post #595630 28th May 2021 11:56am
albertocsoares
Kot wrote:
PM me
PM sent, thank you!
Post #595631 28th May 2021 11:57am
albertocsoares
Thank you, I found it now using my computer, had a bad time yesterday looking for the files on my phone.
Post #595633 28th May 2021 12:02pm
AnotherMutley
Glad you found it.
Post #595650 28th May 2021 2:19pm
albertocsoares
Changed the oil cooler gasket, but the problem was not there, the mechanic says it may be the EGR valve, what do you guys think?
Thank you all
Post #595669 28th May 2021 5:05pm
AnotherMutley
I know this is a bit like closing the stable door after the horse has bolted but have you pressure tested the coolant system to see where the leak is coming from? Coolant leaks can be a pain in the .... to find, there is a UV additive on the market that you put in the system to aid diagnosis. Normally on the 4.4, its either the Thermostat housing, Oil Cooler o-rings or one of the pipes.
Post #595732 29th May 2021 11:14am
albertocsoares
Yes we did the pressure test, it came from the right back top of the engine, going down to the top of the starter. We drained the system and pumped smoke on it but unfortunately it did not work. We are now taking the EGR out to see if we find anything there. Thank you all for the help!
Post #595733 29th May 2021 11:36am
EGR is a PITA on the 4.4... I hope you get it sorted sir... Thumbs Up
Post #595787 30th May 2021 1:04am
