Home > Technical (L322) > TD6 Starter motor location |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
I'm sure it's on the N/S of engine (righthand side as you look into bonnet) |
9th Apr 2011 4:58pm |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
Yes - that's what I thought as the positive lead from the battery goes down there - also the other side is taken up with the exhaust and the turbo.
9th Apr 2011 5:24pm |
Never removed one, but usually remove the live lead and a couple of mounting bolts. A lot depends on how much you have to remove to get to it and the space to work around starter.
9th Apr 2011 6:27pm |
I'm dubious that its an easy job due to its location under the manifolds |
9th Apr 2011 8:12pm |
