Home > Maintenance & Mods (L405) > Under sealing chassis?
Nabi
United Kingdom 2015 Range Rover Autobiography SDV8 Montalcino Red
Evening All,
I know the car rides on an aluminium chassis, but has anyone gone to the bother of under-sealing it and what are folks opinion?
Coming from a 2015 Disco 4 which was pretty rough underneath after a couple of years, so undersealed it and it was great. Understand that the D4 is a steel chassis, but just looking at some preventative work that I can do to prolong it's life?
Thanks
Nick R
Post #595885 30th May 2021 8:14pm
Bloke
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Not sure underseal would be the best approach. Have a look see here - https://www.dinitroldirect.com/affiliated-...directory/
Post #595889 30th May 2021 8:24pm
DrRob
Lanoguard is the new boy on the block... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #595901 30th May 2021 9:12pm
Not the chassis BUT, there are plenty of rusty steel parts like, rear ARB unit, fuel tank guard, steel clips & clamps holding aluminium coolant pipes to the body for example... Brake pipes! Thats what ive found on mine... Thumbs Up
Post #595910 31st May 2021 1:06am
TJH1985
Craig, can you remove the shields easily enough? Nothing to support underneath once removed.
Ours are just starting to corrode as well, might be night to whip them off and spray them with a epoxy mastic.
Thanks
Tom MY17 Santorini Black L494 Autobiography 5.0 SC - Sorry!
Previously Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #596040 1st Jun 2021 6:07am
