Home > Maintenance & Mods (L322) > Air suspension inactive
Tesh
United Kingdom 2004 Range Rover Vogue Td6 Java Black
It would appear that my compressor is goosed
Ive done a few searches and everything seems to point in this direction
Only thing is, it has locked itself in standard ride height (light is illuminated on the switch) is this normal?
I havent had any problems previously and have read that it should of been throwing up messages for a few weeks before giving up the ghost
Anyone got any ideas??
Post #59584 9th Apr 2011 6:54pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
A simple check is to look at the wiring that runs around the front struts, on mine they had worn through against inside of wheel/tyre. Just turn the steering full lock to lock and look underneath the wheelarch.
Both sides on mine were wearing through.....
Post #59585 9th Apr 2011 6:59pm
Tesh
Ive checked the wires and they look ok
Ive disconnected the pump in the boot and both lights have gone off altogether Confused
Post #59586 9th Apr 2011 7:35pm
letsavit2
try putting ignition on and turning full lock left then right, if you have not got a fault message it may do it. If not it will need connecting up to testbook etc. 2004 black Vogue TD6
Post #59595 9th Apr 2011 8:58pm
dan_uk_1984
You say your compressor is goosed? How have you come to this conclusion?
The EAS System is made up of various components, failures of any of these can cause problems.
The fact that it has locked itself into standard height points more to a failed height sensor, pressure sensor, valve or cross-link valve.
Take a look at the EAS Activate, this will allow you to read and reset the code - you can only reset after you've fixed the issue...
http://www.rswsolutions.com/index.php?opti...;Itemid=77
Post #59599 9th Apr 2011 9:12pm
Tesh
Ah I see
Is there any way to sort this without a EAS Activate??
Cheers
Post #59618 10th Apr 2011 8:07am
dan_uk_1984
Tesh wrote:
Ah I see
Cheers
Fix what? You don't know what the problem is yet?
You could go to the dealer for the diagnosis = £120+
You could then fix whatever the issue is = £???
You could then go back to the dealer for the code to be reset = £120+
That's a minimum of £240 - but without knowing the cause the cost could be completely open ended.
D
Post #59620 10th Apr 2011 9:21am
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
When my EAS failed the lights on the hieght adjust button went out and if I flicked it up or down to raise/lower the suspension, the relevant light came on then went out again and nothing happened. What happens if you hit the access height button on the drivers door? By the way mine was the common valve problem (blocked) on the compressor in the boot (@ £7 item if you do it yourself as shown on a thread somewhere on this forum). Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #59744 11th Apr 2011 1:11am
Tesh
The message came on when I was towing the trailer, so it was in standard height and locked. When I tried to adjust it once the trailer was unhitched the corresponding light would flash. Now that I have unplugged the compressor in the boot the lights have gone out and will not come back on
This valve sounds promising, Ive done a search and cant find it Big Cry
Post #59755 11th Apr 2011 8:34am
dan_uk_1984
Shocked Why have you unplugged the compressor!?
You can't adjust the suspension height when a trailer is connected. Sometimes you need an ignition cycle before the system realises the trailer has been disconnected.
Post #59771 11th Apr 2011 11:15am
Tesh
I disconnected the compressor to test it
I am aware the suspension is locked in normal height when a trailer is attached and I did try to adjust it one I had unhitched it
Post #59783 11th Apr 2011 12:20pm
dan_uk_1984
How did you test it? You can't just apply 12V to it as it's a 3 way plug iirc.
Post #59785 11th Apr 2011 12:26pm
Tesh
I know, I found out when I pulled the plug apart
So at present, I still dont know what is wrong with the damn thing
Post #59788 11th Apr 2011 12:29pm
dan_uk_1984
Well, going back to the beginning - you need to get the fault read. The dealer will be able to assist you with this, or EAS Activate. Some independent garages will be able to read and clear the fault too.
Post #59792 11th Apr 2011 12:37pm
pretlove
check you havent blown the fuse as well theres a large fuse in the boot in the right hand side and one in the glovebox "RANGEISM WILL NOT BE TOLERATED"
Post #59805 11th Apr 2011 1:49pm
