Home > Maintenance & Mods (L322) > Water in cupholder
Frubes
United Kingdom 2010 Range Rover Autobiography TDV8 Nara Bronze
Water in cupholder
Hiya
Have noticed water in my centre console cup holder. Dried it up this morning and it's back. Have had air con on given its hot presume it's to do with that?
Any way to stop it?
Cheers
Adam
Post #595954 31st May 2021 3:47pm
fill in your car profile Adam so we know what you have.. ... - .- -.
Post #595964 31st May 2021 4:16pm
Frubes
Done.
2010 tdv8 3.6 autobiography Nara Bronze if it doesn't come up
Post #595997 31st May 2021 7:01pm
Merchy
If the water is collecting in the cup holder, it could be coming from the sunroof, if you have had any rain that is.
Maybe worth pointing a hose at it and see what happens. Sun roof drains could easily be blocked, one thread poster here recently, had water in his car and the sunroof drain area had corroded away completely.
Post #596005 31st May 2021 7:27pm
Frubes
It's definitely not that. It's only happened last two days when it's been boiling hot and I've had the air con on full blast.
Post #596018 31st May 2021 9:06pm
DrRob
Does it do it with the sunroof blind open? You may have condensation building up on the inside of the roof glass and then it drips? Check for leaks in your boot as some have reported 2" in the wheel well.... Shocked Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #596046 1st Jun 2021 8:29am
Frubes
Thinking about it, I think it's only done it when I had the cooled seats on.
Post #596586 6th Jun 2021 9:38am
Merchy
Thinking about the other thread with water produced by the air con system, which is normal, still seems a bit strange to collect in the cup holders, try leaving the cup holders lid open to ensure air flow. If there are no leaks dripping into them it must be down to the humidity and cooling of the seats.
Post #596587 6th Jun 2021 9:44am
