Home > Maintenance & Mods (L322) > Advice please - bush replacement
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
My car feels unsettled when on anything but smooth surfaces. I’ve had the rear sub frame bushes replaced by the garage I bought the car from which improved things for me, but not quite right still.
I have also been advised that the rear upper and front back arm bushes are also worn.
Given the car has covered 155k 115k miles, I am looking to replace all bushes starting with the rear (as it’s worse)
I’m looking to order a bush press kit so I change the rear hub bushes in situ. If I have the bush press kit already, would I be better off buying the rear upper and lower arms still? Or just the bushes? I only ask in case those arm bushes are very tricky, and if I have the arms off anyway then I may as well save myself some hassle?
I’ll also swap the toe control arms while there. Is there anything else I should look to swap while I’m there? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #595988 31st May 2021 6:30pm
See here for what is involved:
https://www.fullfatrr.com/forum/topic17399.html?
If you have the money and the new wishbones come with all the bushes fitted, this might save you a lot of pain and time.
Given I have been there, done that, please ask if you need any insight. .
Post #596019 31st May 2021 9:13pm
Ffrr-lover
That is an excellent write up Joe90! Kudos Thumbs Up
I’ve read everything and note your lessons learned when you started on the RHS - especially breaking it down into smaller jobs like work on the upper in one go, then lower during another stint, etc.
One thing I didn’t realise is the need to use the IIDTool to deflate the bags. I don’t yet have one as its expensive and have other urgent items to pay for! Are there other options? I.e. disconnect the battery, and loosen the airline pipe to let the air out? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #596026 31st May 2021 10:02pm
Yes, if I remember correctly, this is possible, once you remove the inner wheelarches you will find the valve block. You should release the air pressure there.
There was an RSW Solutions video on youtube that showed this method, I can't find it now. I think I have something in my gallery also....found it...
https://www.fullfatrr.com/gallery/displayi...amp;pos=18
note this is for the front valve block, but the rear is a similar approach.
Make sure car is unlocked and keys outside the car before battery disconnection. .
Post #596032 31st May 2021 11:43pm
Ffrr-lover
Appreciate your responses Joe90.
I’ve got a shopping list being pulled together and I’ll let you know when I plan to start!!!
I think I’ll be raiding the garage to eBay a few bits and pieces Wink Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #596118 1st Jun 2021 5:34pm
My 2p would be to buy genuine bushes or arms if you don't want to do the job again in a few months.... Thumbs Up Pete
Post #596125 1st Jun 2021 7:06pm
Ffrr-lover
Agreed! Genuine all the way!!! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #596126 1st Jun 2021 7:26pm
cass
Before you start have you had the wheel alignment checked on a proper 4 wheel alignment checker after the first set of bushes were replaced?
You could be pleasantly surprised at the difference it can make to the drive and it might save you a lot of work
Post #596141 1st Jun 2021 10:01pm
Ffrr-lover
When the rear subframe bushes were replaced the car had a 4 wheel alignment done.
Things have improved with those replaced bushes, but things do still feel loose especially over any rough surfaces. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #596154 1st Jun 2021 11:13pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
In this thread you will see a list of the suspension parts I replaced, it will give you an idea. (ignore non-suspension stuff).
Cheers
https://www.fullfatrr.com/forum/post539270.html L322 3.6 TDV8 Vogue. 07MY
ML 320 7 Seat full leather etc. (The Black Pearl) Wink
Post #596177 2nd Jun 2021 8:03am
Ffrr-lover
Thank you RichM63 for that link. Very useful indeed… especially I am currently writing a list of the things I need and their costs!
Rob at Duckworths has been great at pricing up the parts requested so far (rear only at this stage), but your list gives me prices for the things to do later! Thumbs Up
It’s a scary list mind… Laughing Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #596194 2nd Jun 2021 11:13am
gravitylover
United States 2006 Range Rover Supercharged 4.2 SC V8 Alveston Red
'm pretty sure I have a few bad bushings in the rear of my 06 but just replacing the shocks made a HUGE difference. Less than 2 hours worth of work and it's like a different car.
Post #596887 8th Jun 2021 11:45pm
Ffrr-lover
Thanks gravitylover.
The car went back to the dealer to be looked at with me expecting it to be the strut, but apparently it was fine. They did some form of test which it passed, hence their plan to replace the sub frame bushes.
I didn’t challenge this as the sub frame bush replacement is a fair amount of labour, whereas the strut is relatively simple… so they can do that one for me! Very Happy
I had always planned to change the bushes anyway, and the struts later on down the line too. So I’ll get the rear bushes done (they are worn anyway) and see how the car feels and then plan to do the front bushes or rear struts next.
I also want to service the gearbox and need to do things in the most urgent order as money comes up. Typical, I buy the car and something else in life comes up and costs money I planned to spend on the car! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #596894 9th Jun 2021 7:22am
Ffrr-lover
So I am finally at the point of ordering the new bushes, bars, etc ready to get this job done. It’s been a challenging few months financially due to life getting in the way… but nearly there.
I got the car up and wheels off to have a good look at the state of things…
They are looking a bit sorry! Laughing
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #600997 18th Jul 2021 9:48am
Ffrr-lover
I’ll be following the excellent posts by Joe90 and Fisha… and intend to tackle the rusty areas on the subframe and arms being refitted.
I have the Hammerite paint ready to go!!! Thumbs Up Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #600998 18th Jul 2021 9:53am
