Home > Maintenance & Mods (L405) > A/C Issue
Pat
Scotland 2013 Range Rover Autobiography SDV8 Causeway Grey
A/C Issue
Hi I seem to be having a slight issue with my air conditioning . With all heating controls set to low and ac on the air from drivers vents seems to warmer than passenger vents. Anybody got any ideas
Post #596128 1st Jun 2021 8:35pm
West Yorks V8
Hi Pat
When you do a search, you will see that this is a common issue.
I had the same issue, and followed the advice and had a Re-Gas...... which sorted the problem.
After having P38 Range Rovers I was over complicating the matter, I was convinced that I had a stuck “blend motor” or similar.
Well worth the money, to have the system evacuated and checked, and refilled.
( £185.00 as the Air Con gas is expensive, for the L405)
Hope this helps. Range Rover 4.4 SDV8 Autobiography
Land Rover Freelander 2 SD4
Range Rover P38 4.6
Range Rover Classic LSE 4.2 x 2
Range Rover Classic 3.9
Range Rover Classic 3.5
Post #596148 1st Jun 2021 10:29pm
Pat
Aircon regas
Hi Thanks for that will give it a go
Post #596294 3rd Jun 2021 2:20pm
Bill
I have had it done for much less in France £100.00 ish , I seem to recall RR was slightly more than for others. Might just be size, I’m not sure now.
My tractor was £75.00 (on site) and at the time the main U.K. Citroen dealer was happy to do all comers for £50.00 or so. Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #596297 3rd Jun 2021 3:26pm
Andy B
Some more info here Pat :-
https://www.fullfatrr.com/forum/topic48202.html
Cheers,
Andy
Thumbs Up SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #596304 3rd Jun 2021 4:04pm
