Home > Technical (L322) > No cabin airflow L323 2012 Westminster. Help please ?
TeeMyob
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Hi,
Just spent a stuffy 6 hours in traffic with no airflow from vents.
Car just been serviced and cabin filters changed.
Anyone have advice please ?.
I can hear the fan ok.
Tried all kind of heat/cool/max a/c reset inhibition
Nada
Post #596309 3rd Jun 2021 5:00pm
They fitted the cabin filter still in it's plastic wrapping...???
Just a thought.. Thumbs Up Pete
Post #596320 3rd Jun 2021 6:09pm
^. Crossed my mind as well. Thumbs Up
Take out the cabin filters and see if anything changes.
Post #596323 3rd Jun 2021 6:30pm
Weegie
A bit teaching to suck eggs but have they switched off the aircon? On mine it's the button with the snowflake symbol not sure what the symbol is on yours.
Alternatively, if the above doesn't apply and you are on full auto for the aircon, try pressing the centre button to divert the air to face level. It has worked for me. John
GAP iiD BT-Sold
Post #596325 3rd Jun 2021 6:33pm
TeeMyob
Thanks everyone.
You would never believe it would make so much difference?. But, the cabin filter was in the wrong way around !.
Arrows pointing up, not down.
Post #596331 3rd Jun 2021 7:07pm
TeeMyob
Okay, so here is an update.
Even I thought the Pollen / Cabin Filter in the iron way around wouldn't cause such an issue. However, the reason why I "thought" it had will become clear below.
The airflow stopped again today. So, I pulled over and found the suction pipe (low side of the A/C System iced up. So the front evaporator is clearly frosting up and blocking airflow across the fins. So the frost is a blanket preventing airflow. The rear evaporator must be okay as that works fine.
I did notice when the A/C Was switched off that the ice melted and I saw a tiny billable around the crimp on the hose. So I think the suction/low size hose is leaking.
I have just arrived at my house in Spain, I have some gauges here, a Vac pump and a 11kg bottle of R134a. So will take a look at what is going on in the system.
Post #596543 5th Jun 2021 7:49pm
Alinton
Ireland 2011 Range Rover Vogue TDV8 Zambezi Silver
I'm in Spain too, Alicante. What a a pain it is when the aircon isn't working!
Mine has gone from the fan not coming our of anywhere to none of the zircon buttons or knobs doing anything. Rear outlet is blasting out warm air, the knobs back there have no effect either!
A
Post #596932 9th Jun 2021 2:27pm
TeeMyob
That’s a bigger problem than mine. At least I have the equipment and gas to work with.
That said. New starter and battery just cost me €900
Post #597109 10th Jun 2021 11:54pm
