![]() | Home > Maintenance & Mods (L322) > Air con dripping, how much is normal? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1415 ![]() ![]() |
It all depends on the humidity at the time and how hard the system is working to achieve the set point.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
I’d say that’s not uncommon. The drip bit, not tasting things off car park floors 🤣
QuebecTango Member Since: 06 Jan 2019 Location: Brighton Posts: 57 ![]() ![]() ![]() |
You are in a good place, the air con is clearly working well the drain tubes are clear. The amount of water produced is dependent upon humidity & ambient temp. Worry not. |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 439 ![]() ![]() ![]() |
Thanks, Chaps.
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 342 ![]() ![]() |
I used to live in Singapore, the outdoor temperature is 28-32ºC so you have your car aircon running whenever you are driving. All cars have that puddle, it's completely fine. The only time to do something is when your aircon stops working, which in the UK is probably the lifetime of the vehicle unless there is corrosion on the sealed system.
MonkeyMan Member Since: 20 Apr 2021 Location: Ascot Posts: 133 ![]() ![]() ![]() |
In the UK it’s possible for your aircon to stop working, but you don’t notice it for 6 months because there is no need to cool the car down….
Yes, thanks - I do understand the pool of water, it's just that I've never seen so much of it before - it was more than a few drips - it really covered the tarmac. An incontinent L322.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
It's mainly down to the humidity, at sea I have to look after the Air/con which is a necessity in the tropics etc, the air con compressor is the size of a big V8 and in high humidity areas the evaporator section which cools the air can produce tons of water per day, so much so, that we can collect it and drop it into the boiler water feed tank(s). |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
Sounds normal 👍🏻
