Home > Maintenance & Mods (L322) > Radiator/coolant bleed procedure?
gravitylover
United States 2006 Range Rover Supercharged 4.2 SC V8 Alveston Red
I searched but my search-fu is weak.
I need to bleed the system but having a hard time finding a guide. Is it similar to others I've had where the engine is run up to temp then turn on the heater fan inside the car and open the cap or bleed screw for a while until it stops burbling?
Post #596714 7th Jun 2021 2:33pm
gravitylover
I fumbled my way through and got it to where I think it's good. Thanks for all the suggestions! Whistle
Post #596888 8th Jun 2021 11:46pm
Download the workshop manual from the WIKI... it tells all.... Thumbs Up Pete
-Click here for Thread-
Post #596890 8th Jun 2021 11:55pm
Piet
Netherlands 2008 Range Rover Autobiography 4.2 SC V8 Lucerne Green
And, my experience, put the front up as high as you can.
I’ll put her nose up on a road up to a dike, almost 30* up.
And after a lot of bleeding at last this was the trick to do it.
Post #596951 9th Jun 2021 4:04pm
gravitylover
^^ That's a good idea. I do that with the brakes on my bikes, why wouldn't I do it with my car...
It didn't really. For the most part it just says to bleed the system. Thanks for the suggestion though Wink
Post #597497 14th Jun 2021 5:40pm
